Samsung Smart Watches Samsung Galaxy Gear 1 and 2 , Samsung Gear Live , Samsung Galaxy Gear Fit , Samsung Gear S |
04-11-2017, 05:52 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | Code: POGO 400 - плюс. POGO 401 - RX(TX). POGO 402 - TX(RX). POGO 403 - JIG.(301 кОм.) POGO 404 - минус. RX и TX мог перепутать местами. По памяти пишу. NOT tested yet. OWN risk. Thanx in advance. Best Regards |
04-16-2017, 20:19 | #4 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2672325 Status: Offline Thanks Meter: 4 | thank you, adfree! I try some different cases and find answer! POGO400 - VCC POGO401 - none POGO402 - Data- POGO403 - Data+ POGO404 - Ground |
The Following 4 Users Say Thank You to polyanart For This Useful Post: |
05-06-2017, 08:36 | #5 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Gear S2 Attached is my Pinout for simple USB cable. In theory also for SM-R720. With SM-R732 I have successfully tested. But during my Soldering Adventure... I have killed/lost 1 little tiny SMD chip... Now my WiFi BT range decreased... According to SM-R732-TSHOO-7.pdf I have lost: Code: C108 Code: SM-R732-EPLIS-11.pdf Code: C108 L105 So I have chance to find maybe sparepart... Thanx in advance. Best Regards |
08-30-2017, 01:59 | #7 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Please I need help. Maybe Rear Case of SM-R765 is compatible with SM-R760 and contain Flex cable... look at Pics from FCC. Maybe then no POGO Jig nor Soldering mandatory... I can not find correct part number WITH Flex cable... Code: Rear Case SM-R760 GH82-12922A SM-R770 GH82-12954A SM-R765 ??? Thanx in advance. Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
10-04-2017, 12:51 | #9 (permalink) |
Junior Member Join Date: Jul 2016 Location: Pakistan
Member: 2594096 Status: Offline Thanks Meter: 17 | |
The Following User Says Thank You to Talha34214012 For This Useful Post: |
10-28-2017, 07:35 | #10 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Please share if somebody have. I need Service Manual for SM-R765 for study. Thanx in advance. Code: SM-R765A_Tshoo_7.pdf SM-R765A_EVAPL_3.pdf SM-R765A_EPLIS_11.pdf SM-R765A-PSPEC_2.pdf SM-R765A-Direy-6.pdf SM-R765A-COVER_1.pdf |
10-31-2017, 06:06 | #11 (permalink) |
Member: 2600481 Status: Offline Thanks Meter: 0 | hey adfree... bro i was wondering if you could possibly help me fix my gear s2 classic... i just bought it tonight.. for me that is Oct. 30th 2017 i bought it for $50CAD in needing repair condition, when it boots, it boots to a snowy screen and does nothing, i cant get into wireless download mode, i cant get into recovery, i cant boot normally, but i can get into download mode... BUT>>>> out of the 5 gold plates on the board for the usb connection... one of them was broken off the board, and it just so happens to be the GREEN usb communication line, the 5v positive line is good, the ground is good, and the white usb comms line is good... just that killer 4th one broken off... i dont have a magnifier to even begin to attempt a needle point connection, but was hoping maybe you might know of some alt. test points for usb comms?? i found a alt. point for the usb 5v red lead, and the ground, but have not been able to locate usb alt points again, this is a gear S2 Classic... sorry if hijacked, please move accordingly if so.. thanks in advance and i hope i can get my watch booting |
10-31-2017, 08:34 | #13 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Hello. I think I saw your post on XDA... I have tried to answer. As I have written in XDA. Checklist. A. In Download Mode very usefull infos visible. Model name aka Product name in red lettern: SM-R732 or SM-R732X visible? R/L on or off? This Reactivation Lock... Also the other infos are very usefull. Easiest is to make Photo. B. If you need Combination Firmware, PM me... Best Regards |
10-31-2017, 08:42 | #14 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Btw. I have killed few weeks ago my "white pad"... Data - On my test SM-R732... Ripped off with soldered wire during some movement... I have not checked with microscope or other Tools if I am able to solder something again... I was so frustrated and have desoldered the other wires... But you give me hope. To check it maybe in few weeks again. Best Regards |
11-18-2017, 09:32 | #15 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Code: Model Rear Case Charger Dock/JIG SM-R720 GH82-10837A/GH82-10790A GH81-12016G SM-R732 GH82-10804A GH81-12016G SM-R730 ??? GH81-12016H SM-R760 GH82-12922A GH81-12016M SM-R770 GH82-12954A GH81-12016M SM-R765 ??? GH81-12016L http://forum.gsmhosting.com/vbb/12663069-post7.html Maybe somebody could help me please. Thanx in advance. Best Regards |
