Samsung Smart Watches Samsung Galaxy Gear 1 and 2 , Samsung Gear Live , Samsung Galaxy Gear Fit , Samsung Gear S |
01-15-2020, 00:55 | #31 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | Code: A--->Ground B--->DATA+ C--->DATA- D-------------- E-------------- F->VCC/+5V Only idea... maybe wrong. UNTESTED! Code: A->TP_GND B->TP_USB_DM C->TP_USB_DP D->TP_POGO_V_BATTERY E->TP_USB_ID F->TP_V_BUS_5V Names taken from Service Manual.... ABCDEF is on my Photo... Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
01-16-2020, 18:21 | #32 (permalink) |
Junior Member Join Date: Jan 2020 Location: N/A
Member: 2943638 Status: Offline Thanks Meter: 2 | It could be similar to SM-R800! I tested SM-R500 with the USB and it gave me this msg (the last USB device you connected to this computer malfunctioned and Windows does not recognize it) |
01-21-2020, 07:41 | #33 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Tested successfully. SM-R820 / SM-R830 USB Pinout If Windows Device Manager detect unknown device, try again with green and white cable switched... About SM-R500... Still no idea... I found no Service Manual nor I have this device... SM-R600... Pinout seems in Service Manual... 2 wires on left side of board... 2 wires on the other side... something like this... Best Regards |
01-21-2020, 11:33 | #34 (permalink) | |
Registered User Join Date: Mar 2006 Location: Portugal Age: 41
Member: 246072 Status: Offline Thanks Meter: 96 | Quote:
Check if this helps you https://imgur.com/a/pB22GMx | |
The Following User Says Thank You to SpoOnx For This Useful Post: |
01-22-2020, 17:08 | #35 (permalink) |
Member: 2943638 Status: Offline Thanks Meter: 2 | [QUOTE=SpoOnx;13980338]Check if this helps you Thank you so much for this image. I tested it and it works |
The Following User Says Thank You to Rooot For This Useful Post: |
01-22-2020, 22:19 | #36 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | @Rooot You soldered wires? Or found other way to attach wires? Can you check please this Picture? Or you have green cable and white switched? Thanx in advance. Best Regards |
01-27-2020, 20:58 | #37 (permalink) | |
Member: 2943638 Status: Offline Thanks Meter: 2 | Quote:
you need to switch green and white. So it will be black, white, green, blank, blank and then red. You can solder the wire if you want for me. I made a USB interface compatible with this situation. Regards, | |
11-01-2021, 01:46 | #39 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 303976 Status: Offline Thanks Meter: 6 | Attachment 383527Thanks f9r the pics. This ks the pin layout for the Samsunf R895F. Which i think should be the same with the rlprevious watches, since there is no service manual available, if anyone could help would be much appreciated. Last edited by tids2k; 11-01-2021 at 01:51. |
The Following User Says Thank You to tids2k For This Useful Post: |
12-21-2021, 23:06 | #41 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | SM-R860 have 5 more golden TP? https://forum.gsmhosting.com/vbb/14494973-post156.html Please I need USB Pinout for GW4. Who can help? Its Xmas time. Thanx in advance. Best Regards |
05-17-2022, 14:46 | #42 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | User confirmed SM-R860 USB Pinout. He was able to use RDX Tool for Upload Mode... Code: summary.html auto_comment extra_info debug_history boot_reset acpm_dump header kernel platform kevents s2d arrdumpreset arrdumppanic MFC-log-mem MFC-sfr-dmp0 LPD-log-mem LPD-srm-dmp I was to lazy to write from Screenshots... Only as info. Best Regards |
05-21-2022, 20:50 | #43 (permalink) |
Freak Poster Join Date: Aug 2007 Location: USA
Member: 575293 Status: Offline Thanks Meter: 40 | Heres a video I made showing the board from one of the watch charging cradles will connect to port pins and load in Odin For other watches you might have to solder wires to contacts to get it to work |
06-04-2022, 01:41 | #44 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | @cellfonepimp Sorry I can not see your Youtube Video. If it is GW4 related can you please help to fix my problem? I wrote PM to you but got no feedback... Thanx in advance. Best Regards |
