Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Smart Watches > Samsung Smart Watches
Samsung Smart Watches Samsung Galaxy Gear 1 and 2 , Samsung Gear Live , Samsung Galaxy Gear Fit , Samsung Gear S
Old 04-09-2017, 02:25   #1 (permalink)
Member: 420658
Thanks Meter: 211
Gear S3 - SM-R760 - SM-R770 - USB Pinout
Please, need help.
How to connect USB cable to use Odin?
Need correct Pinout.
Thanx in advance.
Best Regards
Old 04-11-2017, 05:52   #2 (permalink)
Member: 420658
Thanks Meter: 211
POGO 400 - плюс.
POGO 401 - RX(TX).
POGO 402 - TX(RX).
POGO 403 - JIG.(301 кОм.)
POGO 404 - минус.
RX и TX мог перепутать местами. По памяти пишу.
Maybe someone can confirm this...
NOT tested yet. OWN risk.
Thanx in advance.
Best Regards
Old 04-15-2017, 10:52   #3 (permalink)
Member: 303976
Thanks Meter: 6
Lol @adfree didnt know you existed here too.
Old 04-16-2017, 20:19   #4 (permalink)
Member: 2672325
Thanks Meter: 4
thank you, adfree!
I try some different cases and find answer!
POGO400 - VCC
POGO401 - none
POGO402 - Data-
POGO403 - Data+
POGO404 - Ground
The Following 4 Users Say Thank You to polyanart For This Useful Post:
Old 05-06-2017, 08:36   #5 (permalink)
Member: 420658
Thanks Meter: 211
Gear S2
Attached is my Pinout for simple USB cable.
In theory also for SM-R720.
With SM-R732 I have successfully tested.
But during my Soldering Adventure... I have killed/lost 1 little tiny SMD chip...
Now my WiFi BT range decreased...
According to SM-R732-TSHOO-7.pdf I have lost:
C108
Please, I need this document:
SM-R732-EPLIS-11.pdf
Or please help me, what is:
C108
L105
So I have chance to find maybe sparepart...
Thanx in advance.
Best Regards
Old 05-29-2017, 09:21   #6 (permalink)
Member: 437258
Thanks Meter: 23
@adfree,
C108
L105
C111
=connection going to WLAn_ant.
The Following User Says Thank You to yhob For This Useful Post:
Old 08-30-2017, 01:59   #7 (permalink)
Member: 420658
Thanks Meter: 211
Please I need help.
Maybe Rear Case of SM-R765 is compatible with SM-R760 and contain Flex cable... look at Pics from FCC.
Maybe then no POGO Jig nor Soldering mandatory...
I can not find correct part number WITH Flex cable...
            Rear Case
SM-R760            GH82-12922A
SM-R770            GH82-12954A
SM-R765            ???
Maybe somebody can share please Service Manual from SM-R730 and/or SM-R765... to learn more about external Connector.
Thanx in advance.
Best Regards
The Following User Says Thank You to adfree For This Useful Post:
Old 09-29-2017, 17:11   #8 (permalink)
Member: 2594096
Thanks Meter: 17
Here are the Confirm and working Pinouts tested by me.
Old 10-04-2017, 12:51   #9 (permalink)
Member: 2594096
Thanks Meter: 17
Here it is http://forum.gsmhosting.com/vbb/f878...nouts-2271685/
The Following User Says Thank You to Talha34214012 For This Useful Post:
Old 10-28-2017, 07:35   #10 (permalink)
Member: 420658
Thanks Meter: 211
Please share if somebody have.
I need Service Manual for SM-R765 for study.
Thanx in advance.
SM-R765A_Tshoo_7.pdf
SM-R765A_EVAPL_3.pdf
SM-R765A_EPLIS_11.pdf
SM-R765A-PSPEC_2.pdf
SM-R765A-Direy-6.pdf
SM-R765A-COVER_1.pdf
Best Regards
Old 10-31-2017, 06:06   #11 (permalink)
Member: 2600481
hey adfree...
bro i was wondering if you could possibly help me fix my gear s2 classic...
i just bought it tonight.. for me that is Oct. 30th 2017
i bought it for $50CAD in needing repair condition, when it boots, it boots to a snowy screen and does nothing, i cant get into wireless download mode, i cant get into recovery, i cant boot normally, but i can get into download mode...
BUT>>>> out of the 5 gold plates on the board for the usb connection...
one of them was broken off the board, and it just so happens to be the GREEN usb communication line, the 5v positive line is good, the ground is good, and the white usb comms line is good...
just that killer 4th one broken off... i dont have a magnifier to even begin to attempt a needle point connection, but was hoping maybe you might know of some alt. test points for usb comms??
i found a alt. point for the usb 5v red lead, and the ground,
but have not been able to locate usb alt points
again, this is a gear S2 Classic...
sorry if hijacked, please move accordingly if so.. thanks in advance and i hope i can get my watch booting
Old 10-31-2017, 07:18   #12 (permalink)
Member: 2600481
nvm... i think the nand is toast...
i was able to connect to odin thru usb... but just sits forever at "writing param-bin"
Old 10-31-2017, 08:34   #13 (permalink)
Member: 420658
Thanks Meter: 211
Hello.
I think I saw your post on XDA...
I have tried to answer.
As I have written in XDA.
Checklist.
A.
In Download Mode very usefull infos visible.
Model name aka Product name in red lettern:
SM-R732 or SM-R732X visible?
R/L on or off? This Reactivation Lock...
Also the other infos are very usefull.
Easiest is to make Photo.
B.
If you need Combination Firmware, PM me...
Best Regards
Old 10-31-2017, 08:42   #14 (permalink)
Member: 420658
Thanks Meter: 211
Btw.
I have killed few weeks ago my "white pad"... Data -
On my test SM-R732...
Ripped off with soldered wire during some movement...
I have not checked with microscope or other Tools if I am able to solder something again...
I was so frustrated and have desoldered the other wires...
But you give me hope.
To check it maybe in few weeks again.
Best Regards
Old 11-18-2017, 09:32   #15 (permalink)
Member: 420658
Thanks Meter: 211
Model            Rear Case        Charger Dock/JIG
SM-R720            GH82-10837A/GH82-10790A    GH81-12016G
SM-R732            GH82-10804A        GH81-12016G
SM-R730            ???            GH81-12016H
SM-R760            GH82-12922A        GH81-12016M
SM-R770            GH82-12954A        GH81-12016M
SM-R765            ???            GH81-12016L
I am still not able to find correct part number for SM-R765 Rear Case...
http://forum.gsmhosting.com/vbb/12663069-post7.html
Maybe somebody could help me please.
Thanx in advance.
Best Regards
Page generated in 0.22299 seconds with 9 queries
