Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Smart Watches > Samsung Smart Watches
Samsung Smart Watches Samsung Galaxy Gear 1 and 2 , Samsung Gear Live , Samsung Galaxy Gear Fit , Samsung Gear S
Old 01-15-2020, 00:55   #31 (permalink)
Member: 420658
Thanks Meter: 164
USB Pinout is in Service Manual from SM-R820 / SM-R830...
A--->Ground
B--->DATA+
C--->DATA-
D--------------
E--------------
F->VCC/+5V
Only idea... maybe wrong. UNTESTED!
A->TP_GND
B->TP_USB_DM
C->TP_USB_DP
D->TP_POGO_V_BATTERY
E->TP_USB_ID
F->TP_V_BUS_5V
Names taken from Service Manual.... ABCDEF is on my Photo...
Best Regards
Old 01-16-2020, 18:21   #32 (permalink)
Member: 2943638
Thanks Meter: 2
It could be similar to SM-R800!
I tested SM-R500 with the USB and it gave me this msg (the last USB device you connected to this computer malfunctioned and Windows does not recognize it)
Old 01-21-2020, 07:41   #33 (permalink)
Member: 420658
Thanks Meter: 164
Tested successfully.
SM-R820 / SM-R830 USB Pinout
If Windows Device Manager detect unknown device, try again with green and white cable switched...
About SM-R500... Still no idea...
I found no Service Manual nor I have this device...
SM-R600... Pinout seems in Service Manual...
2 wires on left side of board... 2 wires on the other side... something like this...
Best Regards
Old 01-21-2020, 11:33   #34 (permalink)
Member: 246072
Thanks Meter: 96
Originally Posted by adfree View Post
Oh, seems 6 Pins is not sooo new...
Here Photos from SM-R500 GWA...
Öhm... new year new attempt.
Somebody knows the USB Pinout from SM-R500?
Please.
Thanx in advance.
Best Regards
Check if this helps you
https://imgur.com/a/pB22GMx
The Following User Says Thank You to SpoOnx For This Useful Post:
Old 01-22-2020, 17:08   #35 (permalink)
Member: 2943638
Thanks Meter: 2
[QUOTE=SpoOnx;13980338]Check if this helps you
Thank you so much for this image. I tested it and it works
The Following User Says Thank You to Rooot For This Useful Post:
Old 01-22-2020, 22:19   #36 (permalink)
Member: 420658
Thanks Meter: 164
@Rooot
You soldered wires?
Or found other way to attach wires?
Can you check please this Picture?
Or you have green cable and white switched?
Thanx in advance.
Best Regards
Old 01-27-2020, 20:58   #37 (permalink)
Member: 2943638
Thanks Meter: 2
Rooot
You soldered wires?
Thanx in advance.
Best Regards
adfree
you need to switch green and white.
So it will be black, white, green, blank, blank and then red.
You can solder the wire if you want for me. I made a USB interface compatible with this situation.
Regards,
Old 02-10-2020, 19:56   #38 (permalink)
Member: 575293
Thanks Meter: 34
I used a pin port from an old charger cradle to connect to the S3 that worked just fine for me, I forgot which one it was though.
Page generated in 0.31124 seconds with 8 queries
