Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
03-09-2009, 14:18 | #46 (permalink) |
Freak Poster Join Date: Oct 2006 Age: 47
Member: 376450 Status: Offline Thanks Meter: 58 | try these codes *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55.. *369#(*) - MENU 7, 4, 6, menu, menu - lock menu *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..) |
04-02-2009, 21:55 | #50 (permalink) | |
Insane Poster Join Date: Mar 2009 Location: IN YOUR HERAT :)
Member: 986764 Status: Offline Thanks Meter: 14 | Quote:
Sagem *#78737322867973738# = *#superfactoryreset# : Resets personal data (remove SIM card first) *#73287489263373738# = *#securitycodereset# : Resets security code to 0000 (remove SIM card first) If you search here in the forum sure you will find the answer , this forum is really a big library then next time i suggest ti you to use the usefull search button..... For example your IMEI is 35074635268234-2 take the four last digits without the 15th digit you have 8234 ----> 8+2+3+4 = 17 modulo 10 = 7 then x =7 if your firmware is DJ3,5C or DJ3,5D or DJ3,5E or DH3,5H then y=5 else if your firmware is DF4,5E or DF4,5F or DH4,6J or DJ4,6G or DG4,5H or DI4,6G then y=4 else if your firmware is JC3,6N or JC3,6O or JC3,6L then y=2 Now power on your phone without sim and put : *226632623XY and Ok Salam For the last time on this forum... TEST MODE CAN'T BE ENTERED ON MYX3D, MYX5D, MIX5M, MYX6 SAGEM MODELS !!! SO STOP POSTING STUPID REQUESTS FOR TEST MODE CODE FOR THESE PHONES. STOP MYX6 UNLOCK CODE REQUESTS AS THERE IS NO CALC FOR IT YET AND PROVIDED FIELDS ARE UNUSEFULL. TEST MODE CAN BE ENTERED ON MW/MC9XX, MW/MY30XX, MYX3, MYX5: FOR MW/MC9XX: *0287257X WHERE X IT'S AN NUMBER BEETWEN 0 AND 9 FOR MW/MY30XX: WITH DX4,X FIRMWARE *2266326234Y WHERE Y=LAST FOUR IMEI DIGITS(WITHOUT CHECK DIGIT) ADDED MOD 10. MOD 10 MEANS THE REST BY DIVISION OF 10. WITH DX3,X FIRMWARE *2266326233Y WHERE Y=LAST FOUR IMEI DIGITS(WITHOUT CHECK DIGIT) ADDED MOD 10. MOD 10 MEANS THE REST BY DIVISION OF 10. FOR MYX3, MYX5: *226632623XY WHERE Y=LAST FOUR IMEI DIGITS(WITHOUT CHECK DIGIT) ADDED MOD 10. MOD 10 MEANS THE REST BY DIVISION OF 10. X IT'S FIRMWARE DEPENDENT AND CAN BE A NUMBER BETWEEN 0 AND 9. U CAN ACCESS FIEL 94 ? THAT'S PERFECT ! WRITE TO FIELD 94 VALUE 0X01 AND U'LL PHONE (M51 AND ABOVE MODELS) WILL BE IN PERMANENT TEST MODE. | |
The Following User Says Thank You to Doctormobile_14 For This Useful Post: |
07-07-2009, 11:43 | #58 (permalink) |
No Life Poster Join Date: Mar 2008 Location: London
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | can some one give me the solution for removing security code (phone lock code) from sagem 411x, the following codes are not working: *#78737322867973738# = *#superfactoryreset# : Resets personal data (remove SIM card first) *#73287489263373738# = *#securitycodereset# : Resets security code to 0000 (remove SIM card first) we can only enter 8 digits upto *#732874 and it is not taking the rest. thanks in advance |
07-08-2009, 10:08 | #60 (permalink) | |
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | Quote:
@ tofiq, could you plz helo me on above?? | |
