Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
02-02-2018, 14:56 | #214 (permalink) | |
Registered User Join Date: Jul 2006 Location: <<SearcH EnginE>>
Member: 307373 Status: Offline Sonork: paypal.me/div859 Thanks Meter: 590 | Quote:
Reading Phone Info.... Connected phone - Nokia 113 Software ver : V 03.42 11-04-13 RM-871 (c) Nokia IMEI : 355198052339366 XappVer : 000008B6 PPM : V 03.42 11-04-13 RM-871 (c) Nokia e5 CNT : Content: e5_059P1K4 V 03.42 11-04-13 RM-871 (c) Nokia Product SN : D59F2EFAH Product code : 059P813 Base Prd.code: 059P4X5 Module code : 0205287 Long Prod.SN : 0 Hardware info======= HWID : 1300 Battery: 3752 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 355198052339366 IMEI spNet : 3A 55 91 08 25 33 39 06 IMEI svNet : 33 55 91 08 25 33 39 16 F8 Sl Conf : 214-07-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : DFDCB97DD617C418 Country : Spain Operator : movistar Lock info: Block 1 L1:Close; Block 2 L1:Close; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 even after flash and rest conter bad code Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm871__03.42.mcusw PPM : rm871__03.42.ppm_e5 CNT : rm871__03.42.image_e5_059P1K4 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 355198052339366 PCcode : 059P813 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : G:\infini\InfinityBox 2.23\InfinityBox\BEST\Backup\Cert\355198052339366_ XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm871__03.42.mcusw Image : rm871__03.42.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:40 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xBB1D ===Flashing [PPM]=== File : rm871__03.42.ppm_e5 Image : package_e5.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41BC0000 , Len : 0x00488E20 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x3BC4 ===Flashing [CNT]=== File : rm871__03.42.image_e5_059P1K4 Image : package_e5_059P1K4.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x421C0000 , Len : 0x00F80000 Flashing , wait ... Region flash done, time : 00:00:22 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x4D64 Flashing done! Total flash time : 00:03:18 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 113 Software Info: V 03.42 11-04-13 RM-871 (c) Nokia IMEI: 355198052339366 PPM version : V 03.42 11-04-13 RM-871 (c) Nokia e5 Product code: 059P813 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Checkings and reset counters... Counters : Key 0 [3] , Fbus 2 [10] Backup data... Backup created... Checking... Counters : Key 0 [3] , Fbus 0 [10] Reset Done! All done Using F-bus count... Sending code 487822554281900 Level : 1 to SimLock Server... Simlock Server Answer: Bad Code... Done! maybe nokia 113 not supported on movistar DB otherwise thanks | |
