Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
10-30-2003, 16:57 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: kinshasa, D.R.C. Age: 59
Member: 31246 Status: Offline Thanks Meter: 54 | help about sagem mw3027 Imei : 351017350442066 version DG4,5V 190302 1603 fields : 0 : 083A15103705440266 191 :19187008 251 : 1D10EBBE 5250:18FA872A6A2765B48E712195D7449981B65D00B72C577 5 5251: 2AC56CE6F4B5249E542F 5709: NOTHING FOUND IN THIS FILED Someone can help and tell me what to do ? |
10-30-2003, 18:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | whats your field 5374? ok, enter this into field 5709, ..... 0E 17 C1 1E if there is no record, create a field and put this value as field 5709, if this did not solve the problem. then give me field 5374. I hope this is your unlock code....locklevel 00 ....4046816774 BR |
10-30-2003, 18:24 | #4 (permalink) |
Member: 13808 Status: Offline Thanks Meter: 163 | what software did you use to read the fields. Use sagemdr or go into hotline menu and check very well or better still tell me the brief history of the phone, if it had been repaired before etc software repair i mean, or what you ve done on the phone... BR |
10-30-2003, 18:29 | #5 (permalink) |
Member: 31246 Status: Offline Thanks Meter: 54 | I read those field through hotline menu and sagemdoctor too. I correct the field 5709 and the phone give now insert sim, no matter if the sim card is inside. |
10-30-2003, 21:13 | #8 (permalink) |
Member: 13808 Status: Offline Thanks Meter: 163 | With your phone its very possible that you can actually read field 1000 ....check to see if you can read...or enter into hotline menu and check if your field 1000 looked like this.... DA 68 E1 0C 51 04 EE 96 05 because field 1000 is the crypted form of field 0 and if the crpyted form of field 0 is not like this, then you have to see IF you can change to this...i suggest that you make backup of your eeprom. BR |
Help about SAGEM RL302 Fix GSM Adapter | realdeepdark | Sagem Hardware Repair Area | 0 | 03-11-2009 16:16 |
help about sagem my210x unlock | sirnavid2010 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 6 | 02-25-2009 08:31 |
Sagem MW3027 please help | kod | Phone Unlocking Codes & Maps | 2 | 10-06-2002 04:03 |
NEED HELP ABOUT SAGEM MC820 | Gsm Trade | Infineon C16X M51 & ARM7 M52 BASED | 0 | 10-15-2000 14:47 |
help about sagem mc939 | DBD | Infineon C16X M51 & ARM7 M52 BASED | 1 | 03-05-2000 04:07 |
