Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
12-09-2014, 19:45 | #4 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1682310 Status: Offline Thanks Meter: 7 | ial the IMEI code. You can retrieve the IMEI/MEID number on virtually any phone by dialing in the universal code. Dial *#06#. You typically will not need to press the Call or Send button, as the IMEI/MEID number will appear as soon as you finish dialing the code.[1] |
The Following User Says Thank You to 123bolbole For This Useful Post: |
12-10-2014, 10:21 | #6 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: GSM Age: 44
Member: 940222 Status: Offline Thanks Meter: 439 | Quote:
Switch on your phone without SIM card Compose *#*#7378423#*#* Select Service Info and then Simlock If X is with Network and it is not 0 you can unlock your phone via code If X is 0 your counter is locked and unlocking via code is not possible. | |
The Following User Says Thank You to arfaoui608067 For This Useful Post: |
12-10-2014, 11:11 | #7 (permalink) | |
Junior Member Join Date: Dec 2014
Member: 2307814 Status: Offline Thanks Meter: 0 | Quote:
Thanks for the info mate. Appreciate it | |
