Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Unlocking Codes & log files Requests > Phone Unlocking Codes & Maps
Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed.
Old 10-30-2003, 16:57   #1 (permalink)
Member: 31246
Thanks Meter: 54
help about sagem mw3027
I have a sagem mw3027, i read all the codes and introduice them. The phone accepts all the codes, but it continues to says sim verrou or dom locked. I try to read it with 30xx infineon what give me the message of error on those fields 251 and 5250.
Imei : 351017350442066 version DG4,5V 190302 1603
fields :
0 : 083A15103705440266
191 :19187008
251 : 1D10EBBE
5250:18FA872A6A2765B48E712195D7449981B65D00B72C577 5
5251: 2AC56CE6F4B5249E542F
5709: NOTHING FOUND IN THIS FILED
Someone can help and tell me what to do ?
Old 10-30-2003, 18:10   #2 (permalink)
Member: 13808
Thanks Meter: 163
whats your field 5374?
ok, enter this into field 5709, ..... 0E 17 C1 1E
if there is no record, create a field and put this value as field 5709, if this did not solve the problem. then give me field 5374.
I hope this is your unlock code....locklevel 00 ....4046816774
Old 10-30-2003, 18:15   #3 (permalink)
Member: 31246
Thanks Meter: 54
thanks Essojay for your reply, the field 5374 is empty too. Can you give what to introduice in ?
Old 10-30-2003, 18:24   #4 (permalink)
Member: 13808
Thanks Meter: 163
what software did you use to read the fields. Use sagemdr or go into hotline menu and check very well or better still tell me the brief history of the phone, if it had been repaired before etc software repair i mean, or what you ve done on the phone...
Old 10-30-2003, 18:29   #5 (permalink)
Member: 31246
Thanks Meter: 54
I read those field through hotline menu and sagemdoctor too. I correct the field 5709 and the phone give now insert sim, no matter if the sim card is inside.
Old 10-30-2003, 18:54   #6 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,567
Angry ...
Hi !
This means that's an error on field 0. Check if it's ok
best regards,
.:hack3r2k:.
Old 10-30-2003, 18:58   #7 (permalink)
Member: 31246
Thanks Meter: 54
field o: 083a15103705440266 is o.k.
Old 10-30-2003, 21:13   #8 (permalink)
Member: 13808
Thanks Meter: 163
With your phone its very possible that you can actually read field 1000 ....check to see if you can read...or enter into hotline menu and check if your field 1000 looked like this....
DA 68 E1 0C 51 04 EE 96 05
because field 1000 is the crypted form of field 0 and if the crpyted form of field 0 is not like this, then you have to see IF you can change to this...i suggest that you make backup of your eeprom.
Old 10-31-2003, 08:57   #9 (permalink)
Member: 31246
Thanks Meter: 54
I try to read it, but it no valid firld number.
[IMG] code is Off
Help about SAGEM RL302 Fix GSM Adapter realdeepdark Sagem Hardware Repair Area 0 03-11-2009 16:16
help about sagem my210x unlock sirnavid2010 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 6 02-25-2009 08:31
Sagem MW3027 please help kod Phone Unlocking Codes & Maps 2 10-06-2002 04:03
NEED HELP ABOUT SAGEM MC820 Gsm Trade Infineon C16X M51 & ARM7 M52 BASED 0 10-15-2000 14:47
help about sagem mc939 DBD Infineon C16X M51 & ARM7 M52 BASED 1 03-05-2000 04:07
Page generated in 0.25351 seconds with 10 queries
