Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
10-16-2002, 10:52 | #1 (permalink) |
Junior Member Join Date: Oct 2002
Member: 16679 Status: Offline Thanks Meter: 0 | Pleas help i need a C45 .map This log file should be sent to GsmHacking.com ************************************************** ****** [Model: Siemens C45][PhoneID: C66D13E6][Desired IMEI: 350673-55-200935] i have read the .log wit the lodder 403 the settings that i use are C45 and read log i have ridden that i must take the settings fot SL45 for my Phone but that have D(S1) Look (BA20 FlashChip) i don't know if that s one is ok i make a 2 log with the SL45 settings thank you LOG File. Version: 4.00 This log file should be sent to GsmHacking.com ************************************************** ****** [Model: Siemens SL45][PhoneID: C66D13E6][Desired IMEI: 350673-55-200935] this is a log from the C45 BA20 FlashChip with se settings SL45 when i bekom a map from you musst i write the map with SL or C settings thank thank thank you |
10-16-2002, 10:55 | #2 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Lithuania Age: 51
Member: 3962 Status: Offline Sonork: 75446 Thanks Meter: 2 | ******************** Section ******************** ***************** ID: C66D13E6 ****************** ********** Old IMEI = XXXXXX-XX-XXXXXX ********** ********** New IMEI = 350673-55-200935 ********** ************************************************* IMEI Block 00 [Siemens C45] 0xBE 0x99 0x30 0x1E 0x4A 0x8B 0x6D 0xD8 0xBF 0xE0 IMEI Block 01 0xF5 0x62 0xE4 0xE1 0x0B 0x0D 0xFD 0x5E 0xA3 0x36 IMEI Block 02 0xB1 0xB6 0x00 0xB4 0x50 0x9D 0x95 0x58 0xD1 0xC6 0xE9 0x22 0x3E 0xD5 0x90 0xEB 0x35 0x3A 0x11 0xEC 0x85 0x48 0x6B 0x59 0x12 0x35 0x61 0xD3 0xD4 0x61 0x06 0xCE 0xDC 0x8E 0xFB 0x5F 0xA4 0x35 0xCD 0x48 0xC0 0x7B 0x18 0x32 0xA6 0x03 0x00 0xC3 0x70 0xE9 0xB0 0x75 0x3B 0x11 0xEE 0xAC 0x2E 0xDD 0x1F 0x7D 0x66 0x25 0x7D 0x00 0x18 0xA6 0x76 0x07 0x02 0x41 0xE2 0xED 0xAE 0x57 0x9F 0x66 0x51 0x80 0x03 0x23 0x61 0xA5 0xA2 0xCB 0xF5 0x13 0x45 0xC4 0xF0 0x23 0x89 0x96 0xB5 0x3F 0x7C 0x0D 0xEC 0x09 0x9F 0xC5 0x7C 0x6B 0x7B 0xA0 0x34 0xB6 0x5A 0xAE 0xB3 0x49 0x1F 0xA7 0xD6 0x96 0x78 0x47 0x96 0x7D 0x5B 0x77 0xA0 0x24 0x4D 0x0D 0x30 0xF5 0x77 0x35 0x40 0x61 0x5C 0x25 0xEE 0xA5 0x64 0xED 0x8C 0xBF 0x66 0xE5 0x6A 0x05 0x50 0xE7 0x3E 0x68 0x67 0x34 0xB0 0xC9 0xB0 0x84 0xED 0x3F 0x3F 0x71 0x97 0x00 0xB8 0xAE 0x1F 0x68 0xC9 0xD7 0xD7 0x46 0xEB 0x66 0xAC 0x84 0x87 0x31 0xA6 0xF0 0x93 0x1E 0x9F 0x6A 0x93 0x90 0xE5 0x8E 0xB8 0x97 0x30 0xE4 0x97 0xC2 0x0F 0xE5 0x1F 0xC4 0x06 0x5B 0x34 0x47 0x82 0xDB 0xC4 0x9C 0xF5 0x40 0xAE 0x7E 0x0F 0xE5 0x85 0xDB 0x14 0xA2 0xC9 0x64 0x1A 0xC7 0x00 0xCC 0x91 0xCB 0xB1 0xA4 0x96 0xD9 0x1F 0x04 IMEI Block 03 0x6F 0xA5 0xD6 0x36 0x59 0xAF 0xEA 0xAD 0xF0 0xB0 0x69 0xC0 0xF9 0x75 0xB3 0x1F 0x90 0xE1 0x93 0xC9 0xE5 0xFB 0x29 0x1F 0x28 0xD7 0x3B 0x6E 0x44 0xCC 0xB4 0x02 0x0E 0x9D 0x9D 0x37 0x44 0xDC 0xC8 0x22 0x4C 0x5F 0xA2 0xCC 0xDD 0x48 0xB3 0x59 0x8D 0xD2 0x02 0x14 0x57 0x6E 0xCA 0xAE 0xE1 0xE7 0x44 0xF8 0x91 0x0D 0xDD 0x56 0xD2 0x3B 0xB6 0x1E 0xAF 0x2C 0xF3 0xF9 0xCA 0x64 0xE0 0x1E 0xF4 0x89 0x64 0xED 0x4D 0xA2 0x1A 0x28 0xB8 0x74 0x3B 0x03 0xB3 0x26 0x44 0x51 0xBC 0x2B 0xC8 0x09 0x1F 0x8B 0xE4 0xC8 0xAA 0x9E 0xD4 0xFF 0x7F 0xA4 0x24 0x5F 0x86 0xF3 0x35 0x2F 0x41 0xF1 0x7A 0x5F 0x8C 0x7F 0x91 0xC0 0x22 0x70 0x97 0xD8 0xB1 0xFF 0x41 0x4D 0x13 0xD9 0xAE 0x1F 0xF9 0x4D 0xFA 0x80 0x5F 0xB5 0xC9 0x96 0xD8 0xA2 0x1F 0x10 0x6A 0x8C 0x81 0xC7 0xEC 0x59 0x05 0xEE 0x16 0x4D 0xFE 0xDD 0xBF 0x53 0x31 0x7F 0xFA 0x51 0x33 0xFE 0x2C 0xD6 0xEF 0x86 0x2F 0xFB 0x52 0xB7 0x91 0xEA 0x9D 0xB1 0xB3 0x9B 0xEC 0xEF 0xDD 0xBA 0xEC 0x10 0xC7 0xC1 0x92 0xC3 0x67 0x19 0x0B 0xC3 0xD1 0x62 0x1B 0x4D 0xC0 0x51 0x87 0x77 0x43 0x5D 0x78 0xF2 0x2B 0x4A 0x5F 0x6F 0x1A 0xF6 0x5D 0xE2 0xD4 0xE7 0x35 0x45 0x9E 0x5E 0x45 0xDF 0x36 0x28 0x84 0x89 0xF0 0xB2 0xEC 0x43 0xC6 0x05 0x10 0x61 ************************************************* |
10-16-2002, 15:24 | #6 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Quote:
fist copy the above map and save it -- than open in text format and than just chnage the ----c45 written above on the top to sl45--- and than save the map-- than write on ur phone and take ur imei writer as sl45 best regards gohar | |
10-16-2002, 15:27 | #7 (permalink) |
No Life Poster Join Date: Dec 2001 Age: 56
Member: 7721 Status: Offline Sonork: 100.1598522 Thanks Meter: 23 | Open map with C45 selection.When map opened, choose SL45 (option autodetect must be off) and write IMEI. You can use writter 4.00 or 4.02 or 4.03 Best regard |
10-16-2002, 17:38 | #9 (permalink) |
Member deceased !! Join Date: May 1999 Location: Wien/Austria Age: 65
Member: 5 Status: Offline Thanks Meter: 1,884 | here is how to modify your map file if you get the following error file is incorrect or havent i told you not to modify it this map has spaces at the end of each line of text we have to remove the spaces in some lines see below (if you highlite the whole text you will see what i mean) ******************** Section ******************** |remove this space ***************** ID: F7E75CD4 ****************** |remove this space ********** Old IMEI = XXXXXX-XX-XXXXXX ********** |remove this space ********** New IMEI = 350170-70-148101 ********** |remove this space ************************************************* |remove this space IMEI Block 00 [Siemens S45] |remove this space 0xFB 0xAC 0x52 0xAA 0xA8 0xED 0xF9 0x97 0xE0 0xFC IMEI Block 01 |remove this space 0x45 0xCC 0xFF 0xCF 0xEC 0xC2 0x5C 0x48 0x9F 0xD9 IMEI Block 02 |remove this space 0xD5 0x25 0x40 0x97 0x25 0x67 0x21 0x6D 0xA2 0x27 0x5E 0xAA 0x28 0xEF 0x92 0xC2 0x18 0x3B 0x01 0x61 0xA8 0x91 0x20 0x9A 0xC5 0xD3 0x79 0x33 0x53 0x39 0xDD 0x7F 0xED 0x21 0x50 0x6B 0x27 0x65 0x05 0x73 0xCC 0xAF 0xD9 0xC9 0x3E 0xEC 0xC3 0x9F 0x33 0x91 0xE3 0x8A 0xBF 0xEF 0xB4 0x63 0x71 0xD9 0x34 0xA3 0x55 0x10 0x99 0x67 0xEE 0x1C 0xFE 0x26 0x62 0x99 0xA1 0x94 0xE1 0xF2 0xD4 0x9F 0xDF 0xCF 0x09 0xBD 0xCA 0x6F 0xF7 0x28 0x37 0x79 0x39 0x30 0xD1 0xEC 0xC7 0xF1 0x1B 0xF8 0x43 0xB9 0x18 0x83 0xEC 0x90 0x82 0x2C 0x7B 0x5C 0x83 0x9F 0x6A 0x4B 0x79 0x2F 0x38 0x39 0x4E 0x52 0xB0 0x1A 0x87 0x79 0x80 0xCE 0x42 0x2D 0xC6 0xCE 0xAE 0xDB 0xCA 0xB4 0x9D 0x00 0x40 0x3F 0x58 0x9F 0xDF 0x9E 0x43 0x59 0x2B 0x5F 0xDC 0x25 0x85 0x29 0x43 0x87 0x2A 0x84 0xCD 0x9B 0x4E 0x97 0x09 0x22 0x44 0x8A 0xB4 0x8A 0x17 0xCD 0x18 0x2B 0xDC 0xE3 0x76 0x84 0xA4 0x84 0x34 0x4A 0x35 0xBF 0x30 0x3D 0x19 0xF8 0x4F 0x1E 0x2D 0xE3 0x92 0x90 0x95 0xD7 0xED 0x46 0xC2 0x35 0x64 0x12 0xE1 0xB7 0x45 0xB3 0x54 0x05 0xDD 0x41 0xE8 0x43 0xBA 0xEA 0xF4 0x3B 0x7F 0x4D 0x9C 0x98 0xC1 0x81 0xA0 0x47 0x06 0x68 0x44 0x14 0x87 0x0B 0x73 0xB1 0x2A 0x2B 0x7B 0x9E IMEI Block 03 |remove this space 0x85 0x31 0x00 0x5B 0x67 0x5D 0x55 0x73 0x7C 0x60 0xD7 0xC5 0x4F 0xA2 0x56 0x39 0xF8 0x0D 0xA3 0xDE 0x4F 0xA5 0xB2 0x06 0x89 0xC1 0xB3 0xF7 0xB0 0x31 0xB0 0x77 0xD3 0x1E 0x76 0x87 0x72 0xDA 0x29 0x3A 0x31 0x5D 0x1B 0x21 0x8A 0x1A 0x0C 0xFF 0xD6 0x99 0xA7 0x7A 0xF3 0xFB 0xDF 0x4B 0xC8 0xB2 0xAB 0xCA 0xE7 0xE9 0xA1 0x31 0x25 0xEE 0x21 0x97 0xF5 0xD9 0xA1 0x63 0x1B 0x8D 0x04 0xF7 0xA1 0x10 0xEA 0xD0 0x22 0x31 0xF3 0x85 0x9E 0x98 0x59 0x78 0x02 0x5F 0xA3 0x6F 0x2C 0xD5 0x3B 0x93 0x3A 0x9B 0xB3 0x14 0x45 0xC7 0xEC 0xBC 0xAF 0xCA 0xDE 0xC6 0x99 0xA6 0x68 0x71 0xF3 0xAD 0x60 0x7C 0x56 0x84 0xE8 0xA5 0x9E 0x54 0x94 0x8A 0xC9 0x2E 0x9D 0x60 0x04 0x9B 0x86 0x7D 0x63 0x9F 0x60 0xEE 0x56 0x65 0x3C 0x91 0xC2 0x53 0x42 0x5E 0x55 0x88 0x0D 0x8C 0xC6 0x64 0xD1 0x77 0x71 0xB6 0xC6 0x9E 0x97 0x13 0x94 0xA2 0x51 0x0F 0x6F 0xC9 0x6B 0xD6 0x88 0x61 0x5C 0xE6 0x47 0x2F 0xF2 0x8D 0xA7 0x9D 0x55 0xD5 0xCF 0x26 0xF0 0x32 0x59 0x53 0xAC 0x79 0xC6 0xF9 0xC0 0x0C 0x60 0xD2 0xB0 0xA6 0xED 0x8B 0x29 0xDB 0x25 0xC7 0x11 0x0B 0xB9 0x6C 0x60 0xC4 0xC6 0x4F 0xA0 0xC4 0xB3 0x17 0x7F 0x8B 0x14 0x15 0xED 0xA5 0x50 0x5E 0x2A 0xDD 0x04 0x60 0x22 0x9B 0x1B 0x56 0x9F 0x1F 0x53 0x49 ************************************************* |remove this space | you must have two blank lines at the end of the map | you must have two blank lines at the end of the map thanks to minder for his works wbr Winner 58 |
Need the C45 Map | HandyMan2000 | Phone Unlocking Codes & Maps | 10 | 12-04-2002 16:33 |
Help me calulate this C45 map please | krajok | Phone Unlocking Codes & Maps | 4 | 09-29-2002 11:25 |
In need of c45 map | mp3hot | Phone Unlocking Codes & Maps | 3 | 07-29-2002 19:11 |
NEED 2 C45 Map files , thx | mp3hot | Phone Unlocking Codes & Maps | 6 | 07-09-2002 03:57 |
I need the C45 map | mongkolc | Phone Unlocking Codes & Maps | 1 | 06-28-2002 22:09 |
