Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Unlocking Codes & log files Requests > Phone Unlocking Codes & Maps
Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed.
Old 07-04-2002, 22:52   #1 (permalink)
Member: 7398
Please canculate for me this log.
My log:
LOG File. Version: 3.00
This log file should be sent to [email protected]
[Model: Siemens C45][PhoneID: 14D6F540][Desired IMEI: 350673-54-220217]
Thanks
Old 07-05-2002, 04:22   #2 (permalink)
Member deceased !!
Winner58's Avatar
Member: 5
Thanks Meter: 1,883
******************** Section ********************
***************** ID: 14D6F540 ******************
********** Old IMEI = XXXXXX-XX-XXXXXX **********
********** New IMEI = 350673-54-220217 **********
IMEI Block 00 [Siemens C45]
0x5E 0x62 0x00 0x8E 0x6E 0x9B 0x9E 0xC8 0x1F 0x68
IMEI Block 01
0x75 0x95 0x84 0xFE 0xCB 0xBD 0x88 0x3E 0x48 0xF9
IMEI Block 02
0x1B 0x47 0x23 0xA2 0xC5 0x97 0x89 0xD1 0x9C 0x36
0xF8 0xBF 0xF2 0x17 0x77 0xCF 0xCE 0xF8 0xC1 0x59
0x37 0x4D 0x7B 0x5A 0x0F 0xC7 0x57 0x7B 0xE1 0x61
0x42 0x7F 0x61 0xD0 0x7E 0x47 0xE9 0x65 0x55 0xC7
0x6F 0x8E 0xAC 0x80 0x79 0x15 0x93 0x72 0x1A 0x97
0x16 0x74 0x36 0xCF 0x3A 0x60 0x84 0xFE 0xFA 0xAA
0x82 0x24 0xED 0x2A 0xE1 0xAA 0xFD 0x7C 0x94 0x0A
0x72 0x8E 0x19 0xF2 0x88 0x45 0xEB 0x2C 0x96 0xB2
0xA2 0x07 0x83 0xDE 0xE7 0x6C 0x4E 0x3D 0x7B 0x33
0x75 0x64 0x48 0x81 0x6D 0x51 0xCE 0x26 0x75 0xC1
0x7A 0x16 0x13 0x80 0x15 0x13 0x30 0x44 0x7C 0xDE
0x0F 0x11 0xBB 0x35 0x68 0x81 0x3D 0x89 0x4D 0x01
0x83 0xB2 0x58 0x6E 0xD7 0x81 0x1C 0x22 0xC7 0x70
0x18 0x1D 0x5C 0x9E 0xB7 0x0D 0xC7 0x70 0x1F 0xC7
0x1E 0x4F 0x58 0x24 0x2B 0xB7 0x6D 0x89 0xA1 0xF3
0xBC 0x2C 0x7A 0xB5 0x4B 0xBE 0xBA 0xDC 0xBA 0x7C
0x16 0xD7 0xC0 0xEA 0xD1 0x19 0x5B 0xC7 0x3F 0xC2
0x5D 0xCC 0x1F 0x83 0x4F 0x97 0x33 0xEA 0x78 0x68
0xF6 0x58 0x49 0xE6 0x58 0x73 0xEA 0x4E 0x2A 0x70
0x35 0xB2 0x4E 0x19 0xAD 0x20 0xE5 0x55 0x97 0xB2
0xB2 0x5A 0xE4 0xF5 0x1C 0x3A 0xD4 0x4E 0x13 0x01
0x20 0x19 0x98 0x58 0xBA 0xBD 0xF3 0x1E 0x28 0x63
0x21 0x5D 0xFD 0x31
IMEI Block 03
0xE7 0xC3 0x12 0xBF 0x5F 0x02 0xA7 0xD7 0x77 0xD4
0xE5 0x3D 0xB9 0xD5 0x8C 0x5B 0xBB 0x33 0x0D 0x5C
0x06 0xDF 0xB2 0x1B 0xB1 0xE7 0x71 0xE4 0x41 0xC0
0xEC 0xE7 0x4A 0x93 0xA5 0x9C 0x66 0x0E 0x90 0xE1
0x01 0xE2 0x3C 0x47 0xB5 0x47 0x0E 0xA4 0x01 0x81
0xAB 0xB6 0x90 0x0C 0x12 0xEB 0x37 0x02 0xF2 0x8C
0xA4 0x66 0x66 0x35 0x21 0xCE 0x25 0x76 0x14 0x94
0x13 0xC7 0xE4 0x90 0xB6 0x49 0x69 0xAD 0x18 0x90
0x2C 0x6D 0xC9 0x07 0x33 0xD4 0xC8 0xC1 0x1B 0x2E
0x87 0x09 0xD8 0xA4 0x8A 0x54 0x3D 0x30 0x0C 0x48
0xBD 0xD1 0xC7 0xE3 0xA5 0x29 0xEB 0xBE 0x1E 0x38
0xB8 0x6F 0x35 0x8C 0xCA 0x89 0x94 0x3E 0x55 0x06
0x0D 0x93 0x9D 0x9E 0xD9 0x12 0x6F 0x44 0x0D 0x51
0xF3 0x67 0xF2 0xF2 0xEA 0x1B 0xCF 0xA9 0x46 0x3D
0x23 0xD0 0x25 0xCD 0x9D 0x87 0x06 0xD4 0x18 0x27
0x49 0x23 0x71 0xA5 0x51 0x2C 0xE9 0xE5 0x50 0xA9
0x81 0x05 0x15 0x5A 0xFF 0x0D 0xBB 0x0C 0x67 0xC0
0xA8 0xB3 0x7C 0x35 0x8A 0x2B 0x9A 0x67 0xFF 0x3A
0x55 0x14 0x82 0x99 0x14 0xFB 0xF0 0xAA 0xE4 0x82
0x25 0xD0 0xAC 0xC7 0x1A 0x2B 0xC2 0x7D 0x88 0x6D
0x7C 0x3C 0xE4 0xBD 0x36 0xC8 0x6B 0xB5 0x49 0x78
0x3B 0xF5 0x5C 0x56 0xCC 0x3B 0x56 0x9B 0xA0 0x41
0xEA 0x07 0xE2 0x76 0x23 0xAF 0x64 0xDC 0xB5 0xE5
0x73 0x55
wbr
Winner 58
Old 07-05-2002, 08:15   #3 (permalink)
Member: 7398
Hi Winner58,
Thanks for your help. But i can not create map file to upload it to phone. Could you please send to me this map file.
Old 07-05-2002, 22:19   #4 (permalink)
Member: 7398
To Winner58
Please create for me this map file.
Thanks
Old 07-05-2002, 22:54   #5 (permalink)
Member deceased !!
Winner58's Avatar
Member: 5
Thanks Meter: 1,883
here is how to modify your map file if you get the following error
file is incorrect or havent i told you not to modify it
this map has spaces at the end of each line of text we have to remove
the spaces in some lines see below
(if you highlite the whole text you will see what i mean)
******************** Section ******************** |remove this space
***************** ID: F7E75CD4 ****************** |remove this space
********** Old IMEI = XXXXXX-XX-XXXXXX ********** |remove this space
********** New IMEI = 350170-70-148101 ********** |remove this space
************************************************* |remove this space
IMEI Block 00 [Siemens S45] |remove this space
0xFB 0xAC 0x52 0xAA 0xA8 0xED 0xF9 0x97 0xE0 0xFC
IMEI Block 01 |remove this space
0x45 0xCC 0xFF 0xCF 0xEC 0xC2 0x5C 0x48 0x9F 0xD9
IMEI Block 02 |remove this space
0xD5 0x25 0x40 0x97 0x25 0x67 0x21 0x6D 0xA2 0x27
0x5E 0xAA 0x28 0xEF 0x92 0xC2 0x18 0x3B 0x01 0x61
0xA8 0x91 0x20 0x9A 0xC5 0xD3 0x79 0x33 0x53 0x39
0xDD 0x7F 0xED 0x21 0x50 0x6B 0x27 0x65 0x05 0x73
0xCC 0xAF 0xD9 0xC9 0x3E 0xEC 0xC3 0x9F 0x33 0x91
0xE3 0x8A 0xBF 0xEF 0xB4 0x63 0x71 0xD9 0x34 0xA3
0x55 0x10 0x99 0x67 0xEE 0x1C 0xFE 0x26 0x62 0x99
0xA1 0x94 0xE1 0xF2 0xD4 0x9F 0xDF 0xCF 0x09 0xBD
0xCA 0x6F 0xF7 0x28 0x37 0x79 0x39 0x30 0xD1 0xEC
0xC7 0xF1 0x1B 0xF8 0x43 0xB9 0x18 0x83 0xEC 0x90
0x82 0x2C 0x7B 0x5C 0x83 0x9F 0x6A 0x4B 0x79 0x2F
0x38 0x39 0x4E 0x52 0xB0 0x1A 0x87 0x79 0x80 0xCE
0x42 0x2D 0xC6 0xCE 0xAE 0xDB 0xCA 0xB4 0x9D 0x00
0x40 0x3F 0x58 0x9F 0xDF 0x9E 0x43 0x59 0x2B 0x5F
0xDC 0x25 0x85 0x29 0x43 0x87 0x2A 0x84 0xCD 0x9B
0x4E 0x97 0x09 0x22 0x44 0x8A 0xB4 0x8A 0x17 0xCD
0x18 0x2B 0xDC 0xE3 0x76 0x84 0xA4 0x84 0x34 0x4A
0x35 0xBF 0x30 0x3D 0x19 0xF8 0x4F 0x1E 0x2D 0xE3
0x92 0x90 0x95 0xD7 0xED 0x46 0xC2 0x35 0x64 0x12
0xE1 0xB7 0x45 0xB3 0x54 0x05 0xDD 0x41 0xE8 0x43
0xBA 0xEA 0xF4 0x3B 0x7F 0x4D 0x9C 0x98 0xC1 0x81
0xA0 0x47 0x06 0x68 0x44 0x14 0x87 0x0B 0x73 0xB1
0x2A 0x2B 0x7B 0x9E
IMEI Block 03 |remove this space
0x85 0x31 0x00 0x5B 0x67 0x5D 0x55 0x73 0x7C 0x60
0xD7 0xC5 0x4F 0xA2 0x56 0x39 0xF8 0x0D 0xA3 0xDE
0x4F 0xA5 0xB2 0x06 0x89 0xC1 0xB3 0xF7 0xB0 0x31
0xB0 0x77 0xD3 0x1E 0x76 0x87 0x72 0xDA 0x29 0x3A
0x31 0x5D 0x1B 0x21 0x8A 0x1A 0x0C 0xFF 0xD6 0x99
0xA7 0x7A 0xF3 0xFB 0xDF 0x4B 0xC8 0xB2 0xAB 0xCA
0xE7 0xE9 0xA1 0x31 0x25 0xEE 0x21 0x97 0xF5 0xD9
0xA1 0x63 0x1B 0x8D 0x04 0xF7 0xA1 0x10 0xEA 0xD0
0x22 0x31 0xF3 0x85 0x9E 0x98 0x59 0x78 0x02 0x5F
0xA3 0x6F 0x2C 0xD5 0x3B 0x93 0x3A 0x9B 0xB3 0x14
0x45 0xC7 0xEC 0xBC 0xAF 0xCA 0xDE 0xC6 0x99 0xA6
0x68 0x71 0xF3 0xAD 0x60 0x7C 0x56 0x84 0xE8 0xA5
0x9E 0x54 0x94 0x8A 0xC9 0x2E 0x9D 0x60 0x04 0x9B
0x86 0x7D 0x63 0x9F 0x60 0xEE 0x56 0x65 0x3C 0x91
0xC2 0x53 0x42 0x5E 0x55 0x88 0x0D 0x8C 0xC6 0x64
0xD1 0x77 0x71 0xB6 0xC6 0x9E 0x97 0x13 0x94 0xA2
0x51 0x0F 0x6F 0xC9 0x6B 0xD6 0x88 0x61 0x5C 0xE6
0x47 0x2F 0xF2 0x8D 0xA7 0x9D 0x55 0xD5 0xCF 0x26
0xF0 0x32 0x59 0x53 0xAC 0x79 0xC6 0xF9 0xC0 0x0C
0x60 0xD2 0xB0 0xA6 0xED 0x8B 0x29 0xDB 0x25 0xC7
0x11 0x0B 0xB9 0x6C 0x60 0xC4 0xC6 0x4F 0xA0 0xC4
0xB3 0x17 0x7F 0x8B 0x14 0x15 0xED 0xA5 0x50 0x5E
0x2A 0xDD 0x04 0x60 0x22 0x9B 0x1B 0x56 0x9F 0x1F
0x53 0x49
| you must have two blank lines at the end of the map
thanks to minder for his works
wbr
Winner 58
Old 07-07-2002, 17:30   #6 (permalink)
Member: 7398
To Winner 58
Thanks for your map file.
I have Siemens C45 with flash chip IC is fault. After i changed new IC, flash it with All3/4 v 205 and flash file C4506.flx, read log from phone and write map file to phone. Phone still dead.
Please help me, how to solve this problem?
Thanks.
[IMG] code is Off
KC910 flashing, FTEAM please kindly guide me this is my 1st to us FG for flashing mymiela0419 FuriousGold 2 12-25-2009 20:17
Please calculate me this log rios Phone Unlocking Codes & Maps 2 12-18-2002 22:31
Please calcute for me this LOG (SL42e as SL45) Monty Phone Unlocking Codes & Maps 1 08-19-2002 16:44
Please calculate for me this log. WillGsm Phone Unlocking Codes & Maps 1 07-05-2002 04:23
Page generated in 0.26699 seconds with 8 queries
