Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
02-04-2004, 17:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2001
Member: 4184 Status: Offline Thanks Meter: 1 | ST55 codes I need codes for my ST55. I also have calculator and tried the following but the codes are wrong. IMEI: 351736002854622 Code for NCKKN is: **00012*70976371# Code for NCKKN-2 is: **00013*76769770# Code for NSCKN is: **00022*70976571# Code for NSCKN-2 is: **00023*76969770# Code for SPCKS is: **00032*70779571# Code for SPCKS-2 is: **00033*77956770# Code for CKCCK is: **00042*70799571# Code for CKCCK-2 is: **00043*77937170# Code for PCKKP-2 is: **00052*70976371# Code for PCKKP is: **00053*74769770# I've entered: **00032*70779571# result: SIM MEP lock failed **00012*70976371# result: Invalid password **00053*74769770# result: Invalid password Thank you very much in advance! |
02-04-2004, 18:01 | #2 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Austria
Member: 32882 Status: Offline Thanks Meter: 2 | Hi, a few days ago I had the same problem... in my case I was able to solve it this way: 1. put the SIM into the phone 2. enter Code-43 (CKCCK-2) (with SIM inside) 3. enter Code-12 (with SIM inside) Maybe youŽll get an error message again - ignore it! - it doesnŽt matter the phone should be opened... plz post the results of your work Greetz |
02-04-2004, 18:18 | #3 (permalink) |
Member: 4184 Status: Offline Thanks Meter: 1 | Thanks for the reply. I tried the way you said but I got error messages and the phone is still locked. I put SIM card inside that the phone accepts. Should I try with a SIM card that the phone doesn't accept?! Thanks! |
06-25-2004, 01:33 | #4 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Guadeloupe Age: 50
Member: 9955 Status: Offline Thanks Meter: 7 | try Try theses codes and post result here please Phone Code Old: **00053*74769770# Net Code Old: **00012*70976371# Phone Code New: **00053*41954768# Net Code New: **00012*66769571# |
06-25-2004, 02:34 | #5 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Bosnia and Herzegovina
Member: 19493 Status: Offline Sonork: 100.1596420 Thanks Meter: 185 | This solution work 100% 1. put the SIM into the phone 2. enter Code-[52] (with SIM inside)put this code until PIN BLOCKED 3. enter Code-12 (with SIM inside)-put this code until BLOCKED That`s all, phone is unlocked .This is my solution and work on all ST55 W.B.R. |
09-17-2004, 12:51 | #8 (permalink) | |
No Life Poster Join Date: Jul 2003 Location: Austria Age: 43
Member: 35153 Status: Offline Thanks Meter: 64 | Quote:
- Enter the code below 11 times: **00012*00000000# - Ignore 'Code Error' messages | |
09-17-2004, 21:04 | #9 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Poland Age: 46
Member: 43823 Status: Offline Thanks Meter: 308 | @psycho - you got for sure ST55 new - if you want to generate an 100% code free (not temporary remove like entering 11x0000...) then please check here -- Br Multi-COM Ltd. Boguslaw, POLAND |
09-17-2004, 23:15 | #10 (permalink) | |
Member: 19493 Status: Offline Sonork: 100.1596420 Thanks Meter: 185 | Quote:
Maybe ur phone isn`t locked on this [ 12 ] level Try some others levels [13. 22. 23. etc.] B.R. | |
09-19-2004, 06:20 | #11 (permalink) | |
Freak Poster Join Date: Mar 2004 Age: 47
Member: 57268 Status: Offline Thanks Meter: 1 | Quote:
is the method 11x0000 really a temporary method!!!???? | |
09-22-2004, 19:35 | #13 (permalink) |
Member: 43823 Status: Offline Thanks Meter: 308 | @anis76: yes - client with locked phone may back to you in 1 day/week/month or mayeb never when simlock on his phoen appears like a Zorro without revious appoitment )) |
St55 Code Enter??? | ziko | E-Gold Based Phones | 1 | 09-22-2004 18:03 |
ST55 Code Calculator in JAVA !! | Kunio | E-Gold Based Phones | 15 | 12-17-2003 13:42 |
Free ST55 Code calculator by Winiu | winiu | Siemens-Benq RingTones and WallPapers | 11 | 11-07-2003 08:59 |
ST55 code request | Greenhorn | E-Gold Based Phones | 0 | 10-17-2003 09:24 |
ST55 code pleez | gyuszko | Phone Unlocking Codes & Maps | 2 | 10-10-2003 19:16 |
