Phone Unlocking Codes & Maps All threads regarding Phone's Free Unlocking codes or Maps. Spamming and double Requests are not Allowed. |
10-29-2013, 19:22 | #962 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 310325 Status: Offline Thanks Meter: 5 | thank you but does not work, it tell me invalid code This is the modem imformation: Modem COM port : COM16 Mode : 0 CGMM name : MF665C IMEI : 357550040169834 Firmware : CLA_AR_MF665CV1.0.0B03 Full CGMR responce : BD_MF665V1.0.0B05,MF665C,MF665-2.0.0,ZTE CORPORATION,PCW_CLAARGV1.0.0B01,PCW_CLAARGMF665CV1 .0.0B05,PCM_CLAARGV1.0.0B01,PCM_CLAARGMF665CV1.0.0 B04,,,CLA_AR_MF665CV1.0.0B03 Dashboard version : WM_CLAARGMF665CV1.0.0B05 Modem CDROM status : Enabled Chipset platform : ICERA Lock status: Locked (PH-NET PIN) |
10-29-2013, 19:55 | #963 (permalink) | |
No Life Poster Join Date: Sep 2008
Member: 856406 Status: Offline Thanks Meter: 1,022 | Quote:
The Following User Says Thank You to hawa For This Useful Post: |
10-29-2013, 20:38 | #965 (permalink) |
Member: 310325 Status: Offline Thanks Meter: 5 | This is a screenshoot of the dashboard! http://i39.tinypic.com/2j2uel1.gif Last edited by k2k00; 10-29-2013 at 20:47. |
10-29-2013, 22:13 | #969 (permalink) |
Member: 310325 Status: Offline Thanks Meter: 5 | Hello, i have another modem, can we try with this? Readed modem info: Modem COM port : COM12 Mode : 0 CGMM name : MF665C IMEI : 357550040077953 Firmware : CLA_AR_MF665CV1.0.0B03 Full CGMR responce : BD_MF665V1.0.0B05,MF665C,MF665-2.0.0,ZTE CORPORATION,PCW_CLAARGV1.0.0B01,PCW_CLAARGMF665CV1 .0.0B05,PCM_CLAARGV1.0.0B01,PCM_CLAARGMF665CV1.0.0 B04,,,CLA_AR_MF665CV1.0.0B03 Dashboard version : WM_CLAARGMF665CV1.0.0B05 Modem CDROM status : Enabled Chipset platform : ICERA Lock status: Locked (PH-NET PIN) Thanks in advance |
10-29-2013, 22:20 | #970 (permalink) | |
NCK : 61375764 ............................. | |
10-29-2013, 22:25 | #971 (permalink) |
Member: 856406 Status: Offline Thanks Meter: 1,022 | Try this soft too. click here 1. Plug in the internet modem you wish to unlock. 2. Select the make of your Modem from the Manufacturer's List and also Select the Correct Model of your Modem from the Drop-down or use the Auto-Select if you dont know your Modem Model. 3. Then Click on the Microscope Icon to Auto Search and Detect your Modem. 4. Tick on the Read Unlock Code & Auto enter to Modem 5. Click on the Do Job Button and your Modem will successfully Unlocked. |
10-29-2013, 23:05 | #972 (permalink) | |
Member: 310325 Status: Offline Thanks Meter: 5 | Quote:
Do you have this app? | |
