Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Smart Watches > Pebble and Pebble Steel
Old 11-18-2014, 18:34   #1 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
PebbleOS Firmware Release Note
Firmware 2.7 is out!
The headline feature this release is a new API that enables developers to arrange for their apps to launch at some future time. Once they're updated, timers and alarms can time and alarm in the background. Developers can take a look at our app wakeup guide.
Pebble Developers // Using the Wakeup API
Other than that, there are some bugfixes
You can also take a look at https://developer.getpebble.com/2/changelog-2.7.html
The Following User Says Thank You to Braycel For This Useful Post:
Old 11-23-2014, 02:54   #2 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Firmware 2.8 released, featuring an expanded character set!
All system GOTHIC fonts are expanded to contain 351 characters (not counting emoji)
Add setlocale and i18n_get_system_locale APIs in preparation for internationalization support
Fix an issue that could cause an incorrect accelerometer sampling rate to be used
Fix an issue causing wakeup events scheduled less than thirty seconds in the future to fail
Improve the performance of very small resource reads
Fix an issue where iOS calendar alert notifications sometimes did not appear
Fix an issue sometimes causing spurious "Loading..." notifications to appear on iOS
Improve behaviour when trying to boot with a critically low battery
You can grab the update through your mobile app, as usual.
Old 02-06-2016, 16:14   #3 (permalink)
Member: 2527558
Page generated in 0.13703 seconds with 8 queries
