BST / BSTPro Dongle BestSmartTools Official Support Section |
03-19-2018, 08:49 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2091560 Status: Offline Sonork: 000000 Thanks Meter: 44 | 2013062 MI3W Hang on logo done via Bst Dongle. here My use Firmware tested http://bigota.d.miui.com/V8.0.2.0.MX...82c5c1dc11.tgz Fw.Ver : BstKey V3.40 Serial : 3C0C-0B0B-5E39-70F3 Active User: DATU LAKAY PL2303 : 3.4.62.293 2013-10-17 Best Smart Tools, Load OK. Scanning devices ...1 found dev[1] a456230d Mode: fastboot Hardware: MSM8974 Manufactory: UNKNOWN MID: [IMEI Repair] > Backup phone original QCN before Repair IMEI or Erase IMEI/NVM. 1. Power on the phone and enable "USB Debugging" option. 2. Connect phone to pc via USB cables. 3. Dial(*#*#717717#*#*), Enable Qualcomm Diag port. 4. Press "Scan" button to confirm phone connected. 5. Press "EraseIMEI" (or Press "EraseNVM") 6. Repair IMEI 7. Repair Network [Screen Lock] 1. Enter fastboot mode (install drivers if needed) 2. Press "OneKey Recovery" 3. Waiting phone enter recovery mode 4. Press "Scan" and then press "Reset Screenlock" Tips: If you device Bootloader locked, have to unlock bootloader lock before Remove screenlock. [Account Lock] 1. Enter Fastboot or EDL mode (install drivers if needed) 2. Press "Scan" and then press "Reset Account Lock" Tips: 1).If phone locked still or Wifi not working, please do WIPE or flash firmware to fix problem. 2).If phone auto relock after online, please use "Patch Account Lock Relock" or "Disable Account Lock Relock" to fix problem [Factory Reset] 1. Enter Fastboot or EDL mode (install drivers if needed) 2. Press "Scan" and then press "Factory Reset" Boot to EDL mode ... done Wait device ready ...timeout Boot to EDL mode ... done Wait device ready ...timeout Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Wait device ready ... Connect to Sahara (COM57) ... send loader failed! Wait device ready ... Connect to Sahara (COM57) ... send loader failed! Boot to EDL mode ... device must in fastboot mode Prepare environment ...Need reboot device to normal Need reboot device to normal Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Perform device factory reset ... device must in fastboot mode Perform device factory reset ... Wait device ready ... Sending Loader ... Send loader failed! Perform device factory reset ... Writing data ... OK Boot to EDL mode ... done After Force EDL Mode operation , you need to re-flash phone , otherwise device will stuck in EDL mode.Wait device ready ...timeout 2 Wait device ready ... Connect to Sahara (COM178) ... Sending Loader ... Writing data ... Writing sbl1.mbn -> sbl1 Writing rpm.mbn -> rpm Writing tz.mbn -> tz Writing emmc_appsboot.mbn -> aboot Writing dummy.img -> misc Writing dummy.img -> logo Writing boot.img -> boot Writing recovery.img -> recovery Writing persist.img -> persist Writing non-hlos.bin -> modem Writing system.img -> system Writing cache.img -> cache Writing userdata.img -> userdata Writing gpt_main0.bin -> primarygpt Writing gpt_backup0.bin -> backupgpt Done Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Boot to EDL mode ... device must in fastboot mode Boot to EDL mode ... device must in fastboot mode Boot to EDL mode ... done After Force EDL Mode operation , you need to re-flash phone , otherwise device will stuck in EDL mode.Wait device ready ... Connect to Sahara (COM178) ... Sending Loader ... Writing data ... Writing Writing sbl1.mbn -> sbl1 Error in writing to the device, Error code: 2 Done Wait device ready ... Connect to Sahara (COM178) ... Sending Loader ... Writing data ... Writing Writing sbl1.mbn -> sbl1 Writing rpm.mbn -> rpm Writing tz.mbn -> tz Writing dummy.img -> ddr Writing emmc_appsboot.mbn -> aboot Writing dummy.img -> misc Writing dummy.img -> logo Writing boot.img -> boot Writing boot.img -> boot1 Writing recovery.img -> recovery Writing non-hlos.bin -> modem Writing non-hlos.bin -> modem1 Writing system.img -> system Writing system.img -> system1 Writing cache.img -> cache Writing userdata.img -> userdata Writing gpt_main0.bin -> primarygpt Writing gpt_backup0.bin -> backupgpt Done Boot to EDL mode ... done After Force EDL Mode operation , you need to re-flash phone , otherwise device will stuck in EDL mode.Wait device ready ... Connect to Sahara (COM178) ... Sending Loader ... Writing data ... Writing sbl1.mbn -> sbl1 Writing rpm.mbn -> rpm Writing tz.mbn -> tz Writing emmc_appsboot.mbn -> aboot Writing dummy.img -> misc Writing dummy.img -> logo Writing boot.img -> boot Writing recovery.img -> recovery Writing persist.img -> persist Writing non-hlos.bin -> modem Writing system.img -> system Writing cache.img -> cache Writing userdata.img -> userdata Writing gpt_main0.bin -> primarygpt Writing gpt_backup0.bin -> backupgpt Done |
The Following 2 Users Say Thank You to KIKO_PH For This Useful Post: |
