BST / BSTPro Dongle BestSmartTools Official Support Section |
05-10-2016, 21:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2385655 Status: Offline Thanks Meter: 99 | a510f frp lock remove need sboot files Samsung_FRP_ Reset_ File_MODEM_SM_A500F.rar modem.bin flash but sem and use sboot.bin odion felid Odin3_v3.11.1 Odin3 v3.10.6 Odin3 v3.10.7 sem frb lock on need stock sboot file bst not warking frb remov this modal |
05-12-2016, 10:09 | #4 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Try with flashing this Fw first: Download file TUR-A510FXXU1AOL1-20151223202310.zip Later Fix FRP with sidesync BR allumts Last edited by ..::CHAIN::..; 05-14-2016 at 05:58. Reason: Fix .. |
05-12-2016, 15:51 | #5 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | a510f frp lock remove Try with flashing this Fw first: alredy flash 7 time and this firmware but not warking flashing frb lock on this modal to not warking flash how to solved.......? |
05-12-2016, 18:09 | #6 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,345 | With SydeSincronie and downloading .Apk Or with Sboot. You P.Supporter "Chain" know wery well .....i'm only try to help you but see that you will have Procedure Step by Step...and i cannot do this...have helped enough and w/o are greatfull for this... (Just will have used Search Button will have Solved). BR allumts |
05-13-2016, 17:53 | #8 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | a510f frp lock remove With SydeSincronie and downloading .Apk Or with Sboot. Samsung_FRP_ Reset_ File_SM-A510F.rar not warking and dawnlod support area SM-a510f_Reset-FRP_SBOOT_OJ5_BST.bsp Bypass any Samsung Google Account Lock.apk but not warking alredy try need success boot files |
05-14-2016, 00:45 | #9 (permalink) |
Insane Poster Join Date: Jan 2015
Member: 2321119 Status: Offline Thanks Meter: 119 | Samsung_FRP_ Reset_ File_SM-A510F try this sboot file if not flash this firwmare :TUR-A510FXXU1AOL1-20151223202310.zip then use otg and enable oem shuld work its tested by me the firmwware |
05-14-2016, 19:37 | #15 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | a510f frp lock remove Reply to Thread Bypass-Samsung-Account-Google-lock.apk samsung bypass google verify.apk omg use but not warking how to this modal frb lock on not warking flashing only solved sboot files but ok stock sboot files need...... |
