BST / BSTPro Dongle BestSmartTools Official Support Section |
02-07-2017, 16:27 | #61 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2021458 Status: Offline Thanks Meter: 0 | best dongle uart cable communication problem all drivers installed properly and uart cable connection is correct plzz help gsm best team fast im using windows 7 |
02-07-2017, 16:32 | #62 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Not ask only w/o read a little only becouse are Lazy. Br | |
05-10-2017, 00:34 | #65 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2136076 Status: Offline Thanks Meter: 0 | G920W8 - Galaxy S6 - Can't Connnect URT B"H Hi, * Brand New Phone G920W8 - has *#1234... shows phone is perfect. My UART Cable refuses to connect. Here are the steps so far: 0. Running Windows 7 1. Download latest Software - 3.35.00 2. Dongle Updated Firmware 3. Installed Latest version PL2303 : 2.1.44.226 2017-05-09 - Green light on screen Unlock process as follows: 1. Phone prep: USB Debugging Enabled - ADB connection works great. 2. Plug in phone via USB Cable - Drivers install perfect 3. Click on BST->SCAN - Software ID's the phone perfectly 4. Click on COM PORT Radio button, and then click "UNLOCK" 5. Wait for UART Driver Selection Box to pop-up - YES 6. Switch out cables to UART 523 (Setup properly in BOX) 7. Click on COM12 Prolific USB-to-Serial Comm Port (COM12) 8. Select OK to continue - wait 5 secs..... Dialog comes up with Can't connect to device..... Steps I have taken so far: Went to *#0808# and switched to last selection - didn't work Went to *#0*# B4 pluggin in UART cable - didn't work Any suggestions? I'm frustrated, because I know this should work, but doesn't. Thank you, |
06-20-2017, 10:13 | #66 (permalink) | |
Junior Member Join Date: Apr 2017
Member: 2708332 Status: Offline Thanks Meter: 1 | Quote:
08-01-2017, 10:53 | #68 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1155546 Status: Offline Thanks Meter: 2 | I have same problem too o have been using my BST for 3 years now and never unlocked any phone because of 523k resistor uart cable. Someone asked me to connect with Z3x box and it's same problem. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to manually For This Useful Post: |
08-06-2017, 02:46 | #69 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | please make all operation by usb like other teams.... next year when making new update |
The Following User Says Thank You to magixian For This Useful Post: |
11-04-2017, 16:59 | #75 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2774123 Status: Offline Thanks Meter: 1 | BST dongle activation Hi Just Use my dongle and plug into my laptop but no respond. Where to get the serial number for the dongle? thks |
The Following User Says Thank You to ant2umob For This Useful Post: |
