BST / BSTPro Dongle BestSmartTools Official Support Section |
10-02-2013, 07:03 | #1 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | BST Dongle FAQ 1)What Is Mean Of BST? A)BST Is Best Samsung Tool 2)Which Company Phone Supported BST Dongle? A)Samsung And Htc Phones 3)What Is New With Bst Dongle? A)Bst Removed Screen Lock Without Enabled Usb Debug Mode,Without Root And Never To Lost User Data While Remove The Screenlock. Flash/Remove ScreenLock/Unlock/Rebuild IMEI/Repair EFS HTC remove screenlock W/O USB Debugging, dont lost userdata(rooted) HTC Reading/Flash/Backup&Restore/Factory reset/APP2SD 4)Which Samsung Models Supported With Bst Dongle? A)http://forum.gsmhosting.com/vbb/f891...odels-1721783/ 5)BST Dongle Team Have Video Mannuls? A)Yes Here Plz Check This Link Support - GsmBest Technology 6)Bst Have a Own Flash File Support Sever? A)Yes 7)Where Is Buy Bst Dongle? A)Reseller - GsmBest Technology |
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
10-02-2013, 11:44 | #3 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | @Nadim one question for you? while flashing you add efs file!!!!after the flash efs reset or not if reset imei go to 0044999 condition then we need to rebuild imei. next why are you select efs while flash? http://forum.gsmhosting.com/vbb/9773903-post26.html |
10-02-2013, 12:08 | #4 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: >India > China<
Member: 51132 Status: Offline Sonork: 100.1594719 Thanks Meter: 3,722 | Quote:
Nice Question Answer is here 1,We used Efs file because if phone had Baseband or imei null condition by SW; 2,After Efs write problem will be fixed; 3,Now phone imei will be 0044999 condition; 4,Repair imei phone will be done I hope you can understand how easy to use BST Dongle Br, Nadim | |
10-02-2013, 14:26 | #6 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Some details about efs and imei EFS - Embeded File System A partition on your internal memory containing important data including the IMEI. If the data in this partition gets corrupt, you will lose your IMEI IMEI GO TO 0049*** or 0000 meanS your real IMEI is not readable,because it is corrupt EFS HOW TO CORRUPT IMEI WHEN EVER YOU FLASHED ROM VIA CUSTOM RECOVERY OR ODIN CORRUPTED EFS PARTITION ALSO LOST IMEI WHEN IMEI GO TO NULL AND BASE BAND IS UNKNOWN PUT THE PHONE DOWNLOAD MODE,SELECT EFS THEN FLASH IT IF SOFTWARE DEFECT IMEI COME TO 004499 CONDITION JUST REBUILD IMEI YOUR PHONE IMEI AND BASE BAND IS PERFECT NO NEED TO SELECT EFS FILE WHILE FLASHING NOTE IMEI NULL AND BASE BAND UNKNOWN NOT A 100%SOFTWARE DEFECT WHEN RF IC DAMAGED PHONE SHOW THIS SAME PROBLEMS.AFTER WRITE EFS FILE IMEI CANT ENTER 004499 PROBLEM GO TO HARDWARE |
The Following 16 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
