BST / BSTPro Dongle BestSmartTools Official Support Section |
10-21-2014, 16:59 | #121 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Honduras
Member: 1353903 Status: Offline Sonork: 100.1659096 Thanks Meter: 92 | canīt unlock SM-G900T dev[1] Manufactory: SAMSUNG Model: SM-G900T Hardware: QCOM Mode: normal Checking environment ... System Info Display ID: KOT49H System Ver: 4.4.2 REL API Level: 19 Incremental: G900TUVU1ANCH Model: SM-G900T Brand: samsung Device: kltetmo Platform: msm8974 Language: en Rigion: US Device Info SerialNumber: f7909789 Hardware: qcom Model: kltetmo PDA Version: G900TUVU1ANCH Phone Version: G900TUVU1ANCH Bootloader ver: G900TUVU1ANCH Ril Hw Version: REV1.0 Sales Code: TMB Model ID: Get Bluetooth info failed Get WI-FI info failed Network [1]: GSM IMEI: 3533000xxxxxxxx Root Access: ROOTED Time used : 2.8 s Device Authentication ... 1 failed with MSL 1 failed with MSL Time used : 25.0 s |
10-24-2014, 03:47 | #123 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Quote:
Hello, In This Condition You Need To Flash Your Unit 1st Then Repeat Same Process. Regards, --------------- GsmBest Team | |
10-25-2014, 10:35 | #126 (permalink) |
No Life Poster Join Date: Sep 2007 Location: nigeria
Member: 581848 Status: Offline Thanks Meter: 119 | No better solutions again to samsung phones by any team honestly all teams are almost same I believe samsung has developed high secutity system and program via certificate which seems very very hard for coders and reverse enginers ti manipulate unlike the former securities so now its super imei or u do factory unlock.....plz bst team add Factory unlock and repair via credit as an option for safe unlocking to avoid some unlocking issues while we are waiting for breakthrough from direct samsung insider that may leak the secret.....tnks |
10-25-2014, 15:20 | #127 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: Singapore Age: 37
Member: 888712 Status: Offline Thanks Meter: 308 | Quote:
hai bro we buy box ? we need free something right.if need to buy credit ,we buy from server there is cheap.we need only free support .if this team yearly charge we can pay that. br robin | |
10-25-2014, 23:57 | #128 (permalink) |
Junior Member Join Date: May 2013 Location: woodbridge VA
Member: 1933196 Status: Offline Sonork: topcellers Thanks Meter: 0 | I am tryong to go imei repair for Noye 3 N900T but it gives me an error. please help Scanning devices ... 2 found dev[1] Manufactory: SAMSUNG Model: SM-N900T Hardware: QCOM Mode: normal dev[2] Manufactory: SAMSUNG Model: Hardware: Mode: QCDI Selected dev[1] SAMSUNG SM-N900T Exception happended : ?:0: attempt to call field '5a3739968b654ac25166d1443115d8c4' (a nil value) [call stack] [0] : noname [1] : noname [2] : noname [3] : call noname |
10-26-2014, 08:09 | #129 (permalink) | |
if your phone basband ok ,please reset efs then make it supper imei from imei list.if your basband not ok like unknown please reflash the phone when come back basband then you try to repair imei. | |
10-26-2014, 09:05 | #130 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
If not want buy these net code think that you can write other superimei, but will be also in B.List or locked in you country, at the end not has solved nothingh, this dongle not support yet Write/Read Qcn becouse you 'll have solved just writing one Good Qcn from same device with good network unlocked.... You can choice, it's an clear issue with network lock, any 3G or bla..bla.., think now you have all clear, BR allumts | |
10-26-2014, 09:14 | #131 (permalink) | |
Regards allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
10-26-2014, 22:15 | #132 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 540932 Status: Offline Thanks Meter: 36 | > Added GT-I9301I Flash/*ScreenLock/Unlock/(Super)IMEI/EFS/*HW Bro allumts my simple quistion in 3.17 exe i9301i supported or not because i am confusing when i recive these 5 devices i insert sim power on display network lock after repair supper imei all devices goes on insert sim flash again 4.4.2 devices still in insert sim condition u support 2 supper imei same as octopus i have also octopus i repair with octopus all these devices successfully repair no problem insert sim or network check is it a bug or not suppoted this model |
10-27-2014, 12:57 | #133 (permalink) | |
If not have Network is possible that these Superimei are in B.List in you country, superimei is old solution and in New FW get out these network issues, for this the future is only CERT file and QCN for network. If you not know Hot to use CERT file itc..., NOT write that is Bad solution, is the UNIQUE solution with New Fw, is different. Br allumts | |
