BST / BSTPro Dongle BestSmartTools Official Support Section |
03-25-2017, 21:16 | #121 (permalink) |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | Removing Account Lock ... Wait device ready ... Connect to Sahara (COM3) ... Sending Loader ...failed phone only connect in edl model is posible repair phone tkz br treo29 |
03-26-2017, 04:51 | #122 (permalink) | |
Insane Poster Join Date: Jan 2014 Location: Indonesia
Member: 2108563 Status: Offline Thanks Meter: 19 | Quote:
03-26-2017, 08:02 | #123 (permalink) |
Junior Member Join Date: Aug 2011 Location: indonesia
Member: 1631019 Status: Offline Thanks Meter: 5 | bst team why samsung sm-g530h missing repair super imei.,..?? plizz bst team dont missing it, because it is the best repair,,, |
The Following User Says Thank You to zolehl For This Useful Post: |
03-26-2017, 10:27 | #124 (permalink) |
Insane Poster Join Date: Dec 2014
Member: 2304864 Status: Offline Thanks Meter: 21 | thanks...... and add samsung super imei repair..in custom imei option... or add certificat(.IMEI) edit option pls.... some device orginal imei cannot write super imei.. team help pls |
The Following User Says Thank You to yavargsm For This Useful Post: |
03-27-2017, 05:28 | #125 (permalink) |
Junior Member Join Date: Aug 2015 Location: Pakistan
Member: 2442850 Status: Offline Sonork: 100.1670481 Thanks Meter: 3 | Xiaomi Mi 5s Plus Disable Mi Account Lock Tab after "Patch Account Lock Relock" HI, after using "Patch Account Lock Relock" option Mi account has been removed but I am unable to create MI account because in phone setting the MI account tab is not working kindly help me how I can add Mi account in this situation. |
The Following User Says Thank You to abdul.mannan For This Useful Post: |
03-27-2017, 13:07 | #126 (permalink) |
Freak Poster Join Date: May 2014
Member: 2194348 Status: Offline Thanks Meter: 52 | mi5 not working , cant swich or force edl mode not working [Account Lock] 1. Enter Fastboot or EDL mode (install drivers if needed) 2. Press "Scan" and then press "Reset Account Lock" Tips: 1).If phone locked still or Wifi not working, please do WIPE or flash firmware to fix problem. 2).If phone auto relock after online, please use "Patch Account Lock Relock" or "Disable Account Lock Relock" to fix problem [Factory Reset] 1. Enter Fastboot or EDL mode (install drivers if needed) 2. Press "Scan" and then press "Factory Reset" Perform device factory reset ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Perform device factory reset ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Unlocking Bootloader ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Start unlock ... Scan device first Scanning devices ... 1 found dev[1] 1e44c189 Mode: Detect 1 USB devices not install driver Start unlock ... Scan device first |
The Following User Says Thank You to beg-one For This Useful Post: |
03-28-2017, 07:22 | #127 (permalink) |
Member: 1631019 Status: Offline Thanks Meter: 5 | bst v3.34 ( i think it very best bacause button super imei is pop) bst v3.35 ( ithink this update not ***) thanks bst team. |
03-28-2017, 15:37 | #128 (permalink) |
No Life Poster Join Date: Nov 2007 Location: mobile solution
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | j111f frp unlock done Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD Writing files ... ok Operation is completed, please follow these continue to complete unlock operation: > How to Reset Reactivation lock via new method: 1). Create a new Samsung account via PC or another phone (if you had working Samsung account already, skip this step please) 2). Perform "Reset Reactivation/FRP/EE" operation (via download mode) 3). Login samsung account after phone power on and then remove your samsung account (or visit https://findmymobile.samsung.com/ and login with your samsung account, do "Unlock my deivce" and "Unlock Reactivation lock" operation) 4). Make "Factory data reset" operation (or make "Wipe data/Factory reset" via recovery mode if "Factory data reset" failed via phone's menu) > How to Reset FRP/EE lock via new method: 1). Perform "Reset Reactivation/FRP/EE" operation (via download mode) 2). Tick "OEM Unlock" option after phone power on (Settings > Developer options > OEM Unlock) |
The Following User Says Thank You to .::kabir::. For This Useful Post: |
03-29-2017, 14:39 | #131 (permalink) |
Freak Poster Join Date: Apr 2015 Location: NEW DELHI INDIA
Member: 2376362 Status: Offline Sonork: 1664031:mohd Thanks Meter: 49 | Scanning devices ... 1 found dev[1] 9c53901f0000 Mode: normal Hardware: qcom Manufactory: XIAOMI Model: REDMI NOTE 4 Checking environment ... System Info Display ID: MMB29M System Ver: 6.0.1 REL API Level: 23 Incremental: V8.1.15.0.MCFMIDI Model: Redmi Note 4 Brand: xiaomi Device: mido Platform: msm8953 Product: mido Language: en Rigion: US SDCard Info SDCARD[1] RX1BMB > CID: OK > CSD: OK > Type: MMC > Serial: 0x9c54501f > Parts: 50 Device Info Serial number: 0x9c54501f703 Hardware: qcom Bootmode: unknown Bootloader ver: unknown Revision: 0 Main version: Baseband ver: msm GSM baseband: -8953_GEN_PACK-1..1.86804.1 GSM sim state: ABSENT,ABSENT Get Bluetooth info failed WiFi interface: WiFi MAC: 34:80:AF2:f2:7a:04 WiFi state: SCANNING Root Access: No root Get device information done , time used 8.44s Time used : 8.5 s Writing Device Info ... Writing IMEI1 ... Failed (NV550: Parameter is write-protected and thus read only) Writing IMEI2 ... Failed (NV550: Parameter is write-protected and thus read only) Writing MEID1 ... ok How To Wright Imei No. 1 And Imei No. 2 Please Need Solution |
The Following User Says Thank You to mohdfaizan987 For This Useful Post: |
03-29-2017, 15:22 | #132 (permalink) |
Insane Poster Join Date: May 2004 Age: 49
Member: 65522 Status: Offline Thanks Meter: 10 | Samsung g900v reactivation lock not work. Xiaomi redmi 4 (Prime) mi account not work. After this operstion (diactivate lock) mi 4 not work (not downloaded - on logo) |
The Following User Says Thank You to Gortaur For This Useful Post: |
03-29-2017, 15:22 | #133 (permalink) |
