BST / BSTPro Dongle BestSmartTools Official Support Section |
10-11-2014, 14:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: >India > China<
Member: 51132 Status: Offline Sonork: 100.1594719 Thanks Meter: 3,722 | BST Dongle Samsung S5 SM-G900F SuperIMEI Restore (Repair IMEI,No Network,IMEI004999) Tips: 1. IMEI REPAIR ONLY FOR ORIGINAL IMEI RESTORE!!! 2. After SuperIMEI Restore, you can flash ROMs without 2G, 3G, 4G network problem. GsmBest Team www.gsmbest.com |
The Following 5 Users Say Thank You to .:Nadim:. For This Useful Post: |
10-11-2014, 16:29 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 157 | SM-G900A IMEI changed done SM-G900A succesfully changed super imei thanks BST Team Last edited by .::intel32::.; 10-11-2014 at 16:35. Reason: image not uploaded |
The Following User Says Thank You to .::intel32::. For This Useful Post: |
10-11-2014, 18:43 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @.:Nadim:., Post Video en ENGLISH, only few users can understand you language. If you want that also newbie understand procedure, if no continue with China Videos and China Procedure, (Tips). Br allumts |
10-17-2014, 19:01 | #4 (permalink) |
Junior Member Join Date: Jun 2012 Location: Tanzania
Member: 1772399 Status: Offline Sonork: 100.1670951 Thanks Meter: 10 | Today i successfully unlocked SAMSUNG SM-G900F by BST. Thanks to the forum i got manny tips from Disirat, GsmBest-Wei and ect.. Steps i did : 1. Turn usb debugging ON, *#0808# select AP and DM+modem+adb,and reboot the phone. 2. Connect the phone by usb cable and scan. 3. Select 'usb modem' in 'unlock' tab then shift to 'service' tab 4. In 'service' tab select 'write default efs' (phone will turn on download mode and will write default efs and will reboot itself. After reboot if u see the imie it will be ' 01/' - dont panic) 5. Go to 'unlock' tab select 'com port' then shift to 'service' tab. 6. Connect pcb adaptor(i used my z3x box as pcb adaptor coz my pcb adaptor have some problem) and connect UART R523K - both ends to the box and the other to the phone. 7. Do scan again. 8. In 'super imie' option select 'Default' and select a imie as u desire. 9. Now select ' restore imie'. And u will see a dialog screen and select ur com port ( i select z3x box com port coz i used z3x box as pcb adaptor) - u r almost done. 10. Now u will see the super imie u selected after reboot the phone. 11. Finaly connect the phone by usb cable and scan. Then select ' repare 3g'. - DONE. 12. Reboot. Insert sim card and wait 2,3 min for signal. ----------- ENJOY. -----------. |
The Following 4 Users Say Thank You to irshadggl For This Useful Post: |
10-21-2014, 18:34 | #6 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Code: Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G900F Hardware: QCOM Mode: normal Detect 1 USB devices not install driver Prepare environment ... Backup EFS ... D:\BST\backup\samsung\efs\SM-G900F\EFS_samsung_SM-G900F_353750068125528_2014-10-21_19.43.51.zip ok Saving backup file to "D:\BST\backup\samsung\nvm\SM-G900F\NVM_samsung_SM-G900F_353750068125528_2014-10-21_19.43.59.nvm" Backup NVM ... done Time used : 15 min 16 s Reboot device to DOWNLOAD mode ... Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: DOWNLOAD Detect 1 USB devices not install driver Connect to device ... Repair EFS ... Flash completed Time used : 9.8 s Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G900F Hardware: QCOM Mode: normal This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Repair 3G network ... done Reboot device to NORMAL mode ... Re-scan device before any operation please Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G900F Hardware: QCOM Mode: normal Repair 3G network ... done Reboot device to NORMAL mode ... |
10-23-2014, 20:08 | #11 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Quote: | |
The Following User Says Thank You to kawalya For This Useful Post: |
10-23-2014, 22:56 | #12 (permalink) | |
Freak Poster Join Date: Jan 2014 Location: Italy
Member: 2108317 Status: Offline Thanks Meter: 4 | Quote:
i saw this img 1 month ago but we are sure i need this modification ? i mean maybe my dongle it's the new version ? how can i check ? | |
10-24-2014, 12:17 | #13 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
If you want that you Uart cable 530K work with FW 4.3/4.4.2 are Obbligate to welder this 100K resistor, is 2 min.s of work. If not are good to solder this resistor use other Box as Interface whith his Uart Cable, like Z3X, Octopus itc.... BR allumts | |
11-09-2014, 19:12 | #15 (permalink) | |
Insane Poster Join Date: May 2010
Member: 1309486 Status: Offline Thanks Meter: 6 | Quote:
Will "Repair 3G" restore the original IMEI? Well, in my case I end up having that IMEI from the list and the phone now is blocked. am I missing something? | |
