BST / BSTPro Dongle BestSmartTools Official Support Section |
02-07-2014, 19:28 | #1 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1419864 Status: Offline Thanks Meter: 0 | BST dongle tutorial The scan and info work. but when i try to rewrite the IMEI. it does not work . is there any other software should installed ? some one who was trying to help me said i should installed flash rom . I'm not sure exactly what to do. can some one with experience help please ? There arent too many detailed information in English. please help .once I mastermind how to use BST very well ill make a well detailed English version tutorial on YouTube. |
02-07-2014, 23:02 | #2 (permalink) | |
Junior Member Join Date: Jan 2014 Location: In Your smartphone.
Member: 2102900 Status: Offline Thanks Meter: 4 | Make sure u r S4 is not on 4.3 and not on MK2 or Samsung KNOX enable if none of above this is how i fixed [ replace ] my M919 IMEI Here this is what i did with my S4 M919 [ T-Mobile ] ====Flashed my S4 M919 [ tmobile us S4 ] back to 4.2.2 stock Using ODN ====Rooted using CF Auto root [ You can root using other root for AT&T s4 ] If u need help flashing to stock or CF Auto Root serch both on www.xda-developers.com/ ====Turn on Debugging and approved ====I went to *#0808# and selected DM + MoDEM + ADB last option ====Then *#9090# and selected DM/DUM over HSIC then restart ====Plugged phone back to Computer Using Micro USB [ just like when you plug in to transfer data no PCB Adapter:and no UART just normal usb cable ] ====Smart tool Samsung Tab Service selected Com Port on bottom and scan devise [ gave me 2 option on port 1 was Samsung () () QCDI MTP 2 was Samsung SGHM919 QCOM Normal I selected option 2 keep in mind your model number be different then SGH M919 ] ==== Then I press Read at bottom [ ask me for communication Port I selected one My phone was on. I tried all 3 but only one worked lol ] ==== After reading I selected IMEI 1 Tab and filled my new IMEI and pressed write and in 3 second phone restarted and I checked my phone IMEI and it worked Here is my log Quote:
The Following User Says Thank You to maxshah For This Useful Post: |
