BST / BSTPro Dongle BestSmartTools Official Support Section |
10-23-2013, 18:20 | #16 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Kepler22 Age: 46
Member: 2014892 Status: Offline Sonork: 100.1646397 Thanks Meter: 5 | i tried 4 units of i9500 today,1 unit successfull with imei patch.other 3 null/null but i backed up efs for all devices and they are back to working condition now.so patch is working for some hw i9500.thank you bst team. Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9500 Hardware: UNIVERSAL5410 Mode: normal Detect 1 USB devices not install driver Prepare environment ... ok Bypass MSL ... ok Update device ... ok Reboot device to NORMAL mode ... ok Wait device ready ... ok Connect to device ... ok Device Authentication ... ok Writing IMEI ... ok, You need reboot device Time used : 2 min 52 s |
11-15-2013, 21:45 | #21 (permalink) |
Junior Member Join Date: Dec 2008
Member: 930355 Status: Offline Thanks Meter: 0 | I'm i9500 imei patch. IMEI is null null. Gives the following error: Some hardware not support IMEI patch , After reboot done, if baseband becomes 'UNKNOWN' , please re-flash baseband (Phone) to fix it |
11-16-2013, 15:37 | #22 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1185384 Status: Offline Thanks Meter: 17 | Please help, i canīt repair Original IMEI or SUPER-IMEI: Fw Ver : BstKey V3.05 PL2303 : 3.4.48.272 2013-02-05 Best Smart Tools, Load OK. Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9500 Hardware: UNIVERSAL5410 Mode: normal Prepare environment ... ok Patching for IMEI ... ok ---------------------------------------------------- Some hardware not support IMEI patch , After reboot done, if baseband becomes 'UNKNOWN' , please re-flash baseband (Phone) to fix it --------------------------------------------------- Reboot device to NORMAL mode ... ok Re-scan device before any operation please Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9500 Hardware: UNIVERSAL5410 Mode: normal Prepare environment ... ok Bypass MSL ... ok Update device ... ok Reboot device to NORMAL mode ... ok Wait device ready ... ok Connect to device ... ok Device Authentication ... 1 failed with MSL Prepare environment ... Please connect USB cable and re-scan devcie Time used : 2 min 25 s |
11-16-2013, 16:40 | #23 (permalink) | ||
No Life Poster Join Date: Jan 2004 Location: >India > China<
Member: 51132 Status: Offline Sonork: 100.1594719 Thanks Meter: 3,722 | Quote:
if you facing baseband unknown after imei patch, write modem file (Phone) will be fix, after then use SuperIMEI option. Tips:- if not solve please contact us messenger we will check with online viewer thanks. Br, Nadim GsmBest Team | ||
The Following User Says Thank You to .:Nadim:. For This Useful Post: |
11-16-2013, 19:38 | #24 (permalink) | |
Member: 1185384 Status: Offline Thanks Meter: 17 | Quote:
No baseband problem, just can not repair imei, but a friend repaired it with other tool box. I had previously repaired BST i9500 IMEI successfully, following the procedure of support videos. Last edited by .:Nadim:.; 11-17-2013 at 04:59. Reason: Please dont use another product name in this section | |
11-17-2013, 13:23 | #25 (permalink) | |
Member: 930355 Status: Offline Thanks Meter: 0 | Quote:
I've tried a few modem file. But then again, is null null. Which modem should I write the file? | |
11-17-2013, 14:55 | #26 (permalink) |
No Life Poster Join Date: Aug 2004 Location: india Age: 51
Member: 78028 Status: Offline Thanks Meter: 90 | when we can restore our original imei????? still waiting for the correct solution(customers always wish to there own imeis) thanking you |
The Following User Says Thank You to devika For This Useful Post: |
11-18-2013, 08:57 | #27 (permalink) |
Freak Poster Join Date: May 2005 Age: 48
Member: 145829 Status: Offline Thanks Meter: 16 | no change imei only supper imei other box same.. new imei write phone null / null no help no change imei this box i think no new imei write ... same problem a lot people .. ( phone model i9500 0049 imei and imei patch null / null again no com port write new imei ..) ) |
The Following User Says Thank You to Santana1907 For This Useful Post: |
11-18-2013, 11:46 | #28 (permalink) | |
1, Flash working roms (depend on you one pack or fullflash) 2, repair default Efs 3, patch imei ,if baseband imei null after patch imei then use step 1,2 again then use super imei; 4, repair original imei Br, Nadim | |
