BST / BSTPro Dongle BestSmartTools Official Support Section |
08-28-2017, 07:20 | #2 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello Dear, This Phone CPID Based Protection !! So You Cant Write CERT@Moment !! Regards, __________ GsmBest Team |
The Following 3 Users Say Thank You to ..::CHAIN::.. For This Useful Post: |
11-22-2017, 07:26 | #3 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-G570F Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-G570F Android version: 6.0.1 Product code: SM-G570FZKAXFA Phone version: G570FXXU1API8 PDA version: G570FXXU1AQC2 CSC version: G570FOJV1AQC2 CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: MP 0.500 Phone SN: R28H93DR7SL Chip name: EXYNOS7570 Modem board: SHANNON305 RF cal date: 20160929 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (4 23) Done with Samsung Tool PRO v.27.7 |
