BST / BSTPro Dongle BestSmartTools Official Support Section |
12-17-2015, 08:45 | #5 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Time used : 36.6 s Unlocking device ... can't get response from device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Unlocking device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD Unlocking device ... not support this operation |
12-17-2015, 09:04 | #6 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | Hi for SM-G900x models not support please look v3.28.00 release please wait new future updates we will try add Best Regards GsmBest Team |
