BST / BSTPro Dongle BestSmartTools Official Support Section |
12-11-2016, 03:04 | #2 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2536917 Status: Offline Thanks Meter: 5 | Do you have BST Board Version 1.1 or higher? [Check on bottom of board] If not, you'll need to solder a R104 Resister, tutorial is in Forums forum-dot-gsmhosting-dot-com/vbb/f891/attention-uart-4-4-2-needs-soldering-1830484/ If you do have 1.1 or higher, Baseband Version cannot be Unknown. If everything is as it should be, you'll need to have root, of course, use MicroUSB [not UART Cable] Scan, and click Enable UART. After it says OK, rescan, hit Write Cert and connect UART when prompted. |
12-11-2016, 10:23 | #3 (permalink) | |
Freak Poster Join Date: Jul 2009 Location: bin/earth/Pakistan...
Member: 1069698 Status: Offline Thanks Meter: 219 | failed with MSL Quote:
12-12-2016, 19:34 | #5 (permalink) |
Member: 2536917 Status: Offline Thanks Meter: 5 | I'm stuck at this point as well with a G928T, failed with MSL, might need to wait for update to include Bypass MSL exploit. Although I had believed that if you Wipe EFS/Write Default EFS, this would let you bypass MSL, although it looks like you already did those steps. With mine, I cannot get the original IMEI to go away, Wiping EFS and Writing Default doesn't work on my G928T, for now. Hoping updates come soon to support 6.0.1 Baseband/Modem and Bypass MSL |
