BST / BSTPro Dongle BestSmartTools Official Support Section |
05-03-2017, 11:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: From Uzbekistan
Member: 545722 Status: Offline Sonork: 100.1619680 Thanks Meter: 322 | g925f failed with MSL Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Cables: MicroUART Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925F Hardware: SAMSUNGEXYNOS7420 Mode: normal Detect 1 USB devices not install driver This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Device Info (MTP) Model: SM-G925F IMEI: 350000000000006 PDA Version: G925FXXU3DPAD Phone Version: CSC : G925FOXA3DPAD CSC Version: G925FXXU3DPAD SerialNumber: Time used : 40.1 s Checking DRK ... Invalid data Repairing DRK ... failed Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Prepare environment ... check environment failed Time used : 12.1 s Reboot device to DOWNLOAD mode ... Wait device ready ... Connect to device ... Repair EFS ... Flash completed Time used : 2.0 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925F Hardware: SAMSUNGEXYNOS7420 Mode: normal Detect 1 USB devices not install driver Connect to device ... Device Authentication ... failed with MSL Checking DRK ... Invalid data Repairing DRK ... failed Connect to device ... Device Authentication ... failed with MSL Connect to device ... Device Authentication ... failed with MSL Checking DRK ... Invalid data Repairing DRK ... failed Prepare environment ... Enabling UART ... ok Connect to device ... Device Authentication ... failed with MSL Checking DRK ... Invalid data Repairing DRK ... Checking DRK ... Invalid data Checking DRK ... Invalid data Repairing DRK ... Checking DRK ... Invalid data Connect to device ... Device Authentication ... failed with MSL Connect to device ... communication failed Connect to device ... Device Authentication ... failed with MSL Prepare environment ... Device do not have ADB interface, turn on device USB DEBUG and connect with usb cable,then re-scan device Need reboot device to normal Time used : 0.0 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925F Hardware: SAMSUNGEXYNOS7420 Mode: normal Detect 1 USB devices not install driver Prepare environment ... Backup EFS ... D:\BST\backup\samsung\efs\SM-G925F\EFS_samsung_SM-G925F__2017-05-03_15.46.41.efs ok Wiping EFS ... ok Time used : 23.4 s Checking DRK ... Invalid data Repairing DRK ... Checking DRK ... Invalid data Connect to device ... Device Authentication ... failed with MSL Connect to device ... Device Authentication ... failed with MSL Connect to device ... Device Authentication ... failed with MSL Reboot device to DOWNLOAD mode ... Wait device ready ... can't wait a UART connected device boot ready. |
