BST / BSTPro Dongle BestSmartTools Official Support Section |
11-11-2015, 09:52 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: iran.kurdistan
Member: 750365 Status: Offline Thanks Meter: 728 | tnx bro but when i push super imei show this error: use usb : Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds use uart : Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL or 1 failed with MSL This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. |
11-11-2015, 10:13 | #4 (permalink) | |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | Quote:
11-11-2015, 16:53 | #6 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Bangladesh
Member: 715924 Status: Offline Sonork: 100.1662616 Thanks Meter: 83 | Procedure: 01. set mobile in download mode. 02. write default eps. 03. power on phone. connect rj45 cable. 04. press read button. 05. thick user. 06. select super imei. 07. write super imei. tested by me http://forum.gsmhosting.com/vbb/f891...te-ok-2010791/ |
11-12-2015, 10:39 | #7 (permalink) | |
Member: 750365 Status: Offline Thanks Meter: 728 | Quote:
test and ok . tnx | |
