BST / BSTPro Dongle BestSmartTools Official Support Section |
12-26-2014, 10:48 | #3 (permalink) |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | apparently you have a m7 of at&t What is your current LOG ? Do you want install the firmware Android 4.3 sense 5? and later install OTA to 4.4.2 sense 5.5? Step's: [SOLVED] Help Needed for Updating to 4.4.2: … | AT&T HTC One | XDA Forums --The RUU (.exe) Android 4.3 sense 5: http://dl3.htc.com/application/RUU_M...5_signed_2.exe --The OTA (Android 4.4.2 SENSE 5.5) you must relock the Bootloader and you must not modify the cid. |
12-26-2014, 12:15 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: INDIA
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | how to flash without s off this model i downloaded this files but cant install Prepare to flashing ... ok Reboot device to RUU mode ... Wait device ready ... Check battery status ... ok Checking bootloader ... support unlock Checking bootloader lock status ... Locked Device security status is S-ON This rom don't have signature data. S-ON device will check ROM signature Sending data ... device: signature checking... Flash failed, error:status read failed (Too many links) |
12-26-2014, 12:24 | #6 (permalink) |
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | make good and easy update for htc i also try files from support areas but same problem and support aread download speed also so much slow please make easy and tutirial also for htc flash always problem htc ruu mismatch in google and custmon rom not givin good result when set have error so pls make this htc good updates |
12-27-2014, 05:15 | #7 (permalink) | |
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | Quote:
greetings. | |
12-27-2014, 10:39 | #8 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
When you are S-OFF you can flash what you want. P.d. Loock you screen, not to see the ERROR?, "Device is Not S-OFF" BR allumts | |
12-27-2014, 14:36 | #9 (permalink) |
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | then how htc flash if cant find corect ruu without custom rom bcoz many mobile not work custom rom and another ruu cant flash and same vertion cant find on support then bst is usseless for htc if htc have problem like this |
12-27-2014, 15:59 | #11 (permalink) | ||
For to have you device S-OFF+SUPERCID, where you can flash any Custom Rom/RUU itcc... you must need HTC box or for any model Only by Java Card you can have S-OFF+SUPERCID, like ONE X (chipset Tegra). With BST you can flash NOT signed RUU or Rom matching with you CID and Hboot. Is clear now? Or can use Adb & Fastboot command but Only for Right Rom/RUU matching with you cid original. Command in fastboot mode: Quote:
allumts | ||
12-28-2014, 10:20 | #12 (permalink) |
Member: 629327 Status: Offline Sonork: 100.1663374 Thanks Meter: 537 | then which htc box can flash and give matching rom and htc flash all for software problem solution? suggest me htc box for htc flashing |
12-28-2014, 17:26 | #13 (permalink) | |
If you want flash Any C.Rom, any Ruu itc...you M7 must need obbligatory S-OFF+Supercid. More, you M7 isn't International version, (M7_ul), is M7 only AT&T version, then you must need of use Right Box that support this MID: PN0712000, and i cannot write here wich is this box (are in Bst area), use search button and loock for HTC Box. For Sure this model i support by Java Card, S-OFF+Supercid in 30 secons, but i'm in Europe, and to buy Java Card for only this phone is more expensive, arround 400$. Anyway loock a little for ***** Box. BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
