BST / BSTPro Dongle BestSmartTools Official Support Section |
10-24-2013, 16:10 | #2 (permalink) |
Insane Poster Join Date: Aug 2009 Location: jaipur (rajasthan) Age: 52
Member: 1095731 Status: Offline Sonork: nts21713 Thanks Meter: 3 | Mode: normal Detect 1 USB devices not install driver This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device.Prepare environment ... ok Removing Google Locks (this could take 2-3 minutes) … Not supported data Unlock via ADB ... ok Reboot device to NORMAL mode ... ok Re-scan device before any operation please Time used : 58.8 s Checking driver from server ... Can't find driver, Report problem to help us fix it please. Getting latest news ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-N7100 Hardware: SMDK4X12 Mode: normal Detect 1 USB devices not install driver This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.0 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.1 s Prepare environment ... ok Bypass MSL ... Not supported NV data Time used : 11.5 s Device is already rooted Time used : 1.0 s Prepare environment ... ok Bypass MSL ... Not supported NV data Time used : 19.0 s Prepare environment ... ok Bypass MSL ... Not supported NV data Time used : 11.1 s |
10-25-2013, 02:24 | #3 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,491 | Quote:
1. "WR. Default EFS" if phone baseband unknown. 2. "IMEI Patch" 3. Fill original IMEI and then click "Write" 4. Change 523K UART cable when software request uart cable. Check Video: HERE Best Regards GsmBest Team | |
10-25-2013, 07:47 | #4 (permalink) | |
Member: 1095731 Status: Offline Sonork: nts21713 Thanks Meter: 3 | Quote:
