BST / BSTPro Dongle BestSmartTools Official Support Section |
05-30-2015, 09:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: EMMC
Member: 2228324 Status: Offline Thanks Meter: 79 | how to repair n5100 imei repair? [ANSWERED] Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-N5100 Hardware: SMDK4X12 Mode: normal ----------------------------------------------------- Download: Press Vol Dn + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Type *#9090# set Diag Config to LOG VIA USB. Cables: MicroUSB Interface:Auto Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Detect 1 USB devices not install driver Prepare environment ... Patching for IMEI ... ok Prepare environment ... Bypass MSL ... Update device ... Reboot device to NORMAL mode ... Wait device ready ... Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 1 min 35 s |
05-30-2015, 09:55 | #2 (permalink) |
Member: 2228324 Status: Offline Thanks Meter: 79 | And here is z3x repair log: :l :l :l BST :l REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Fill values what you need to repair. 5. Press 'Repair' button. 6. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 7. Press 'Disable Factory Mode' if needed. Operation: Repair Selected model: GT-N5100 Software version: 20.3 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-N5100 Android version: 4.4.2 Product code: Not Active Phone version: N5100XXDND8 PDA version: N5100XWDNE2 CSC version: N5100OJVDNE2 CSC country code: UAE CSC sales code: XSG HW version: Unknown Phone S/N: 00000000000 Modem board: XMM6262 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool v.20.3 |
06-03-2015, 09:48 | #5 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Online Thanks Meter: 6,491 | Quote:
GT-N5100 repair imei & unlock via gt-p1000 uart cable please Best Regards GsmBest Team | |
