BST / BSTPro Dongle BestSmartTools Official Support Section |
06-17-2015, 14:18 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | How to unlock sm-g920t System Info Display ID: LRX22G System Ver: 5.0.2 REL API Level: 21 Incremental: G920TUVU1AOCG Model: SM-G920T Brand: samsung Device: zerofltetmo Platform: exynos5 Language: en Rigion: US Device Info SerialNumber: 03157df3aa36d423 Hardware: samsungexynos7420 Model: zerofltetmo PDA Version: G920TUVU1AOCG Phone Version: G920TUVU1AOCG Bootloader ver: G920TUVU1AOCG Ril Hw Version: REV1.0 Sales Code: TMB Model ID: UNKNOWN Get Bluetooth info failed Get WI-FI info failed Root Access: ROOTED Time used : 3.0 s Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 40.1 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.0 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.0 s Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 19.3 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G920T Hardware: SAMSUNGEXYNOS7420 Mode: normal Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 19.3 s user canceled Time used : 17.1 s communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 8.5 s user canceled Time used : 1 min 47 s Scanning devices ... 0 found Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G920T Hardware: SAMSUNGEXYNOS7420 Mode: normal Checking environment ... System Info Display ID: LRX22G System Ver: 5.0.2 REL API Level: 21 Incremental: G920TUVU1AOCG Model: SM-G920T Brand: samsung Device: zerofltetmo Platform: exynos5 Language: en Rigion: US Device Info SerialNumber: 03157df3aa36d423 Hardware: samsungexynos7420 Model: zerofltetmo PDA Version: G920TUVU1AOCG Phone Version: G920TUVU1AOCG Bootloader ver: G920TUVU1AOCG Ril Hw Version: REV1.0 Sales Code: TMB Model ID: UNKNOWN Get Bluetooth info failed Get WI-FI info failed Root Access: ROOTED |
07-10-2015, 10:13 | #3 (permalink) |
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | How to unlock g925t with bst Fw.Ver : BstKey V3.25 Serial : 20F9-675E-5D39-6C19 Active User: zahid2007a PL2303 : 3.4.67.325 2014-09-03 Best Smart Tools, Load OK. Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: offline offline Your device is offline, try follow steps to solve this problem: 1. diable and re-enable your device USB debug 2. reboot your device 3. restart adb service 4. change a usb cable or usb port. Detect 1 USB devices not install driver Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925T Hardware: SAMSUNGEXYNOS7420 Mode: normal ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Cables: MicroUART Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Detect 1 USB devices not install driver Checking environment ... System Info Display ID: LRX22G System Ver: 5.0.2 REL API Level: 21 Incremental: G925TUVU1AOCG Model: SM-G925T Brand: samsung Device: zeroltetmo Platform: exynos5 Language: en Rigion: US Device Info SerialNumber: 04157df443556e09 Hardware: samsungexynos7420 Model: zeroltetmo PDA Version: G925TUVU1AOCG Phone Version: G925TUVU1AOCG Bootloader ver: G925TUVU1AOCG Ril Hw Version: REV0.2 Sales Code: TMB Model ID: UNKNOWN Get Bluetooth info failed Get WI-FI info failed Root Access: No root Time used : 3.0 s Device Authentication ... 1 failed with MSL Time used : 8.7 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925T Hardware: SAMSUNGEXYNOS7420 Mode: normal Detect 1 USB devices not install driver Device Authentication ... 1 failed with MSL Time used : 27.9 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.0 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.0 s This operation need MTP interface, if you are connect device via UART cable, replace with USB cable and re-scan device. Time used : 0.0 s Scanning devices ... 0 found Detect 1 USB devices not install driver Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925T Hardware: SAMSUNGEXYNOS7420 Mode: normal Detect 1 USB devices not install driver Checking environment ... System Info Display ID: LRX22G System Ver: 5.0.2 REL API Level: 21 Incremental: G925TUVU1AOCG Model: SM-G925T Brand: samsung Device: zeroltetmo Platform: exynos5 Language: en Rigion: US Device Info SerialNumber: 04157df443556e09 Hardware: samsungexynos7420 Model: zeroltetmo PDA Version: G925TUVU1AOCG Phone Version: G925TUVU1AOCG Bootloader ver: G925TUVU1AOCG Ril Hw Version: REV0.2 Sales Code: TMB Model ID: UNKNOWN Get Bluetooth info failed Get WI-FI info failed Root Access: No root Time used : 2.6 s Device Authentication ... 1 failed with MSL Time used : 8.5 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925T Hardware: SAMSUNGEXYNOS7420 Mode: normal Detect 1 USB devices not install driver Device Authentication ... 1 failed with MSL If not support read codes, use Unlock instead Time used : 24.8 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G925T Hardware: SAMSUNGEXYNOS7420 Mode: normal Detect 1 USB devices not install driver Device Authentication ... 1 failed with MSL Time used : 26.7 s |
