BST / BSTPro Dongle BestSmartTools Official Support Section |
05-08-2015, 20:31 | #16 (permalink) |
Junior Member Join Date: May 2015
Member: 2390852 Status: Offline Thanks Meter: 2 | |
The Following User Says Thank You to mintec68 For This Useful Post: |
05-08-2015, 21:17 | #17 (permalink) | |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | Quote:
pd: where are you from? | |
05-08-2015, 21:31 | #19 (permalink) | |
you ask, what process you want to do, because my also happened to me that mistake !! and the problem was not the cable !!! (in a i9500). Bye bye. | |
05-09-2015, 06:23 | #20 (permalink) | |
Member: 2390852 Status: Offline Thanks Meter: 2 | Quote:
Why can I connect with N7100 on my first use but later can't? The only reason is because the uart cable is damaged. Can anybody post the schematics for the 2 in 1 uart cable (RJ45 & USB to micro USB)? The schematics posted here is only for RJ45 to USB. Last edited by mintec68; 05-09-2015 at 06:32. | |
05-09-2015, 07:01 | #21 (permalink) | |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | Quote:
05-09-2015, 17:09 | #22 (permalink) |
Member: 2390852 Status: Offline Thanks Meter: 2 | The computer does not detect my phone when I plug into uart cable. It only detected it on my first use. After that it won't detect anymore. I've installed all drivers and software. I tested the jig with a usb cable, it detected my phone. |
10-02-2015, 19:55 | #25 (permalink) | |
Freak Poster Join Date: Aug 2009
Member: 1090661 Status: Offline Thanks Meter: 15 | Quote:
Checking environment ... failed Device Info (MTP) ... failed Time used : 0.1 s I tried with a different cable that works great on z3x and says the same. If I choose the interface right port gets: Scanning devices ... 0 found Device Info (UART) ... failed Time used : 9.0 s I already put the resistor on the pcb because I have v1.1 Any other help? | |
10-02-2015, 20:33 | #26 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | For PCB V1.1 No need any resistor, where no there's anything writed yes need solder resistor. Sure work with UART CLIP setted to 619K or build by yourself one UART cable with 619K of resistor, can desolder resistor in pcb...is V.1.1 no need. Other Sure way is to use other BOX as interface, like Z3X or Octopus, with his Uart cable, this is also 100% tested and working. Hope now is all clear that this pcb ...... not want to talk more about, all TIPs explained. Good Lucky BR allumts |
02-11-2016, 22:44 | #27 (permalink) |
Freak Poster Join Date: Sep 2015 Age: 32
Member: 2460182 Status: Offline Thanks Meter: 7 | 523K for P1000 Cable i wanna repair imei on N8000 but i need 523K resistor for P1000 cable. but the only 523K resistor cable i have is micro-USB which i got when i bought the BST Dongle. and yes i do have P1000 cable which came with BST and yes i did tried but didn't work. what should i do? how can i repair imei on phones and tablet which have P1000 socket with out 533K resistor cable for it? please help! |
02-11-2016, 23:57 | #28 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | P1000 cable NOT goes Modified lol.... Uart cable can build by yourself with one easy diagram that's the same for 99% of Box, all Box that use UNIPINOUT, Z3X, Octopus, Micro-Box itc...only Ns Pro NOT use Unipinout and (not remember good), UFS... LOOCK, but cannot use with this mainbord of BST has inteface, (have also Usb cable, Y cable), here Diagram: Or can use Other Box as Interface with His Uart cable, NO Ns Pro. Anyway explain clear what's you problem with Log and screenshoot. BR allumts |
02-12-2016, 07:11 | #29 (permalink) |
Member: 2460182 Status: Offline Thanks Meter: 7 | thanks for responding quickly this diogram is used for building UART 523K for Micro-USB but i need a diogram to build P1000 UART 523K. and if i may understand you correctly, i must use other boxes like Z3X and their cable as interface to do this. and about the last question: i use Z3X box and cable to repair imei on N8000 so i have not screen or log to share. but there is gonna be something we can do in other to write imei on tablets which have P1000 pin( Sockets) using BST dongle and interface! |
02-12-2016, 08:57 | #30 (permalink) |
Freak Poster Join Date: May 2015 Location: YOU THINK. I DO.
Member: 2401275 Status: Offline Thanks Meter: 78 | Quote: bro this cable use riff jtag box or not.????????????ans bro |
