BST / BSTPro Dongle BestSmartTools Official Support Section |
09-26-2014, 20:57 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2135309 Status: Offline Thanks Meter: 1 | i need to help sm n9005 imei null [ANSWERED] imei null and baseband unknown Checking environment ... System Info Display ID: KOT49H System Ver: 4.4.2 REL API Level: 19 Incremental: N9005XXUGNG1 Model: SM-N9005 Brand: samsung Device: hlte Platform: msm8974 Language: en Rigion: GB Device Info SerialNumber: 32bb528c Hardware: qcom Model: hlte PDA Version: N9005XXUGNG1 Phone Version: Bootloader ver: N9005XXUGNG1 Ril Hw Version: Sales Code: VD2 Model ID: Get Bluetooth info failed Get WI-FI info failed Network [1]: GSM IMEI: null Root Access: No root Time used : 3.3 s |
09-27-2014, 02:25 | #2 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,490 | Quote:
Try to solve problem as follow way: 1. Write Default EFS (Samsung > Service > Repair > Wr.Default EFS) 2. Flashing fullflash 3. Check baseband working or not > If baseband working then "Repair IMEI" and then "Repair 3G" > If baseband unknown still then check phone h/w (modem parts) Best Regards GsmBest Team | |
09-27-2014, 14:41 | #6 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Quote:
Hello, Post Here Your Logs!! Then We Can U Check Where U Wrong ... Check This Thread Hope It Will Helpful For You Good Luck: http://forum.gsmhosting.com/vbb/f891...4-2-a-1797648/ Regards, ___________ GsmBest Team Last edited by ..::CHAIN::..; 09-27-2014 at 14:44. Reason: Link Added!! | |
09-28-2014, 19:30 | #7 (permalink) | |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | your problem is not IMEI, the main problem of your phone is Modem your phone modem is damage and some time its software some time hardware why Software: some time when you flash phone with diffrent region phone modem damage so you must need phone's region full flash and then you can repair Modem or you also can write only modem file so until you repair your \Modem you not able to repair your IMEI if GsmBest-Wei's steps not work then its mean your phone have hardware problem so check hardware for repair modem when your modem ok then read info will show "Phone Version: xxxxxxxxxx" not blank Quote:
The Following User Says Thank You to AsiaGSM™ For This Useful Post: |
