BST / BSTPro Dongle BestSmartTools Official Support Section |
01-22-2014, 23:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1870650 Status: Offline Thanks Meter: 12 | I337 IMEI Repair instruction Please.... I watched all your video... when IMEI repair...you guys use com port...I tried to use pcb adapter and uart cable...phone doesn't recognized... Please helpppppppppp... Thanks |
01-23-2014, 10:40 | #2 (permalink) | |
Junior Member Join Date: Jan 2014 Location: In Your smartphone.
Member: 2102900 Status: Offline Thanks Meter: 4 | Quote:
====Flashed my S4 M919 [ tmobile us S4 ] back to 4.2.2 stock Using ODN ====Rooted using CF Auto root [ You can root using other root for AT&T s4 ] ====Turn on Debugging and approved ====I went to *#0808# and selected DM + MoDEM + ADB last option ====Then *#9090# and selected DM/DUM over HSIC then restart ====Plugged phone back to Computer Using Micro USB [ just like when you plug in to transfer data no PCB Adapter:and no UART just normal usb cable ] ====Smart tool Samsung Tab Service selected Com Port on bottom and scan devise [ gave me 2 option on port 1 was Samsung () () QCDI MTP 2 was Samsung SGHM919 QCOM Normal I selected option 2 keep in mind your model number be different then SGH M919 ] ==== Then I press Read at bottom [ ask me for communication Port I selected one My phone was on. I tried all 3 but only one worked lol ] ==== After reading I selected IMEI 1 Tab and filled my new IMEI and pressed write and in 3 second phone restarted and I checked my phone IMEI and it worked Hopefully it will work for you as well. If it works post result | |
The Following User Says Thank You to maxshah For This Useful Post: |
01-25-2014, 20:03 | #3 (permalink) |
Member: 1870650 Status: Offline Thanks Meter: 12 | Thanks for replying...but I'm stuck in rooting...after flash to SGH-I337_ATT_I337UCUAMF3_4.2.2_FullFlash I couldn't root...I tried over 3 ways...but I couldn't get root... if you know how to root i337UCUAMF...let me know...I tried motochopper, saferoot, impactor, microSD ... but I got some kind of binary error. supersu, superuser...couldn't get root access... I completely stuck rightnow. |
01-29-2014, 06:42 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | change latest superuser .apk and su in motochopper folder. first hardreset ur mobile. try motochopper it will push binaries and su but will fail to root. no problem , now connect with v root. latest. now root ur mobile easily. try and post sucess report. |
The Following User Says Thank You to rajufzr For This Useful Post: |
