BST / BSTPro Dongle BestSmartTools Official Support Section |
08-15-2014, 13:38 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1686318 Status: Offline Thanks Meter: 5 | i9070 unlock problem I just got bstdongle and i'm trying to network unlock a Samsung i9070. I have enabled debugging mode, and tried connecting via usb cable & tried with the 523k uart cable (tried selecting all available com ports from the interface box 1 by 1) but noting is working, everything I try keeps saying it cant find the phone. if I connect via usb cable and click the scan button it reads info from the phone. Please can anyone help? Thanks |
08-16-2014, 07:04 | #4 (permalink) | |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | Quote:
when you click scan button software scan all USB Ports and tell you what is connect with USB with this PC, so once you scan and if your phone is connected with usb then if will show info about phone if Phone not connected with USB then you will have have all box with connected with USB then you have to select correct COM port and need click INFO button not Scan again. when you select correct COM Port and click info you will get phone info by UART cable and can do any job with UART like this. i hope now you understand, Follow my instructions and try to unlock your phone and post result i would like to see logs and screen shoots BR, Nauman Muhammad GSM BST Team | |
The Following User Says Thank You to AsiaGSM™ For This Useful Post: |
08-18-2014, 13:17 | #5 (permalink) |
Member: 1686318 Status: Offline Thanks Meter: 5 | Hi, Thanks for the info, I have followed your instructions and glad to say the phone has now unlocked, thanks for your help. Aaron |
The Following User Says Thank You to aaronmarsh632 For This Useful Post: |
08-20-2014, 18:08 | #6 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2160798 Status: Offline Thanks Meter: 0 | Hi , I followed your intruction and it seems that software has problem when it start to ROOT . I paste my info : Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9300 Hardware: SMDK4X12 Mode: normal Prepare environment ... Se Necesita Acceso root Start Get Root ... will try 6 methods Rooteado con psneuter ... Exception happended : bad argument #2 to '75a808ec26683ba0006c241fc136291b' (no value) [call stack] [0] : noname [1] : noname [2] : noname [3] : call noname [4] : call 5d3dfddd3590f5dfb874bbc045ffef01 [5] : call 532f4470c186d1bdb15296601a9bf396 [6] : call 228535a03e6c0754f619306388989ff9 [7] : call 0478aa525e234d6c170e0d1c385b02be [8] : call de13a9dc0b8f4982f975488d2e89147c [9] : call 6ea68037a19f6e8551c288f7605da7ee [10] : call a6c60c27f2c2f311b13cdbfbeb42e97a [11] : call 75a808ec26683ba0006c241fc136291b Tiempo de Uso : 4.8 s Phone is into debug mode and im connecting it with uart R523k cable. |
08-21-2014, 14:51 | #7 (permalink) |
Junior Member Join Date: Aug 2014 Location: South Africa
Member: 2243921 Status: Offline Sonork: 100.1607480 Thanks Meter: 1 | Hi I followed steps and with the usb cable it sees the phone but when i use the uart cable no phone detects : Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9500 Hardware: UNIVERSAL5410 Mode: normal Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Prepare environment ... check environment failed Scanning devices ... 0 found Device Info (UART) ... failed Time used : 0.6 s Scanning devices ... 0 found Device Info (UART) ... failed Time used : 0.9 s thank you v_dubs |
08-21-2014, 23:39 | #9 (permalink) | |
