BST / BSTPro Dongle BestSmartTools Official Support Section |
02-16-2016, 01:59 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: WhereEver
Member: 2109940 Status: Offline Thanks Meter: 490 | i9300 no repair network option [ANSWERED] and you do not put this solution all samsung box have this function for i9300 just suggest |
02-16-2016, 02:03 | #2 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Online Thanks Meter: 6,491 | Quote:
"repair network" option only for samsung qualcomm base models, if you gt-i9300 facing network issue, you can try solve problem as follow way: 1. Flashing full flash 2. Write Default EFS 3. Repair IMEI (or Write SuperIMEI) 4. Reboot phone check network Best Regards GsmBest Team | |
05-01-2016, 19:46 | #3 (permalink) | |
Member: 2109940 Status: Offline Thanks Meter: 490 | . Quote:
the only solution when the imei are good and when dial *#0011# you see imer cert : fail is writing super imei or repair network option and if i wanna write super imei the original imei will be changed we just wanna repair the phone with the original imei this function is released in other boxs from long time thanks in advance | |
05-02-2016, 05:22 | #4 (permalink) | |
No Life Poster Join Date: May 2015 Age: 40
Member: 2394595 Status: Offline Thanks Meter: 24 | Quote:
05-02-2016, 15:47 | #5 (permalink) |
No Life Poster Join Date: Nov 2013 Location: Third World ;)
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | If you have really original imei, you shouldn't need repair network. If imei certi fail is becouse iw was modified. Anyway if you just want to write the same do it, repair imei with same in phone and you will have the same imei with "repaired network". |
05-04-2016, 02:17 | #6 (permalink) | |
Member: 2109940 Status: Offline Thanks Meter: 490 | Quote:
again when do repair imei the imei cert : fail will not solved bro we use a z3x or oct to just press "repair network" or in z3x "PATCH CERTIFICATE " so please do not tell that imei cert will be : pass if i repair imei its not the first time i repair phone network anyway we suggest to add this future for none qualcomm phones so the bst stay the bst | |
