Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 11-02-2013, 11:57   #1 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 43
i9500 baseband unknown & imei Null/null
how can repair????
Scanning devices ... 1 found
dev[1]
Manufactory: SAMSUNG
Model: GT-I9500
Hardware: UNIVERSAL5410
Mode: normal
Checking environment ... ok
System Info
Display ID: JDQ39
System Ver: 4.2.2 REL
API Level: 17
Incremental: I9500XXUAMDL
Model: GT-I9500
Brand: samsung
Device: ja3g
Platform: exynos5
Language: en
Rigion: GB
Device Info
SerialNumber: 4df7078b471140bf
Hardware: universal5410
Model: ja3g
PDA Version: I9500XXUAMDL
Phone Version:
Bootloader ver: I9500XXUBMG9
Ril Hw Version:
Sales Code: THL
Model ID:
Get Bluetooth info failed
Get WI-FI info failed
Network [1]: GSM IMEI: null
Root Access: ROOTED
Time used : 2.2 s
Old 11-02-2013, 13:59   #2 (permalink)
.:Nadim:.'s Avatar
Member: 51132
Sonork: 100.1594719
Thanks Meter: 3,722
@rubymunna
1, Flash working Roms and check baseband and imei, if baseband working imei 0499xx;
2, repair imei or use supper imei;
3, if baseband and imei still null after flash rom then use repair default EFS;
4, repair imei or use supper imei;
Waiting your reply....
Br,
Nadim
Old 11-03-2013, 00:26   #3 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 43
i m stuck here
i put uart cable 523k
stuck cant connect to devices
i m very tired
please help me
http://imageshack.us/a/img818/5061/elct.png
Old 11-03-2013, 03:35   #4 (permalink)
.:Nadim:.'s Avatar
Member: 51132
Sonork: 100.1594719
Thanks Meter: 3,722
Originally Posted by rubymunna View Post
i m stuck here
i m very tired
please help me
Follow like this way:
1, after popup use uart cable / remove usb cable from phone and connect uart 523K cable to bst pcb adapter connect both rj45+usb uart.
Use time 5 to 10 sec if time mismatch will get error.
2, select bst adapter comport and click ok and wait few sec... Will all done
Please try and post result im waiting...
Br,
Nadim
Old 11-03-2013, 17:17   #5 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 43
i try many time same....stuck here
Cant connect to device , please check the cable connection....
i can see on phone changing... bst said Cant connect to device , please check the cable connection
dev[1]
Model: GT-I9500
Mode: normal
System Info
Display ID: JDQ39
API Level: 17
Incremental: I9500ZSUAME1
Model: GT-I9500
Brand: samsung
Device: ja3g
Platform: exynos5
Language: en
Rigion: GB
Device Info
Model: ja3g
PDA Version: I9500ZSUAME1
Phone Version:
Bootloader ver: I9500ZSUAME1
Ril Hw Version:
Sales Code: TGY
Model ID:
Root Access: ROOTED
Time used : 1.8 s
Old 11-03-2013, 19:48   #6 (permalink)
.:Nadim:.'s Avatar
Member: 51132
Sonork: 100.1594719
Thanks Meter: 3,722
@rubymunna
Please fix baseband 1st.
1, flash tested roms and and check baseband.
2, please follow my post #2
Br,
Nadim
Old 11-04-2013, 18:07   #7 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 43
bro try many rom same....
if i put nspro with uart cable...i can see baseband...if i put out uart cable and restart phone...baseband unknown...
Old 11-05-2013, 05:15   #8 (permalink)
.:Nadim:.'s Avatar
Member: 51132
Sonork: 100.1594719
Thanks Meter: 3,722
@rubymunna
Please contact me messenger i will check online.
Br,
Nadim
Old 11-08-2013, 13:55   #9 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 43
i add u on skype......
Old 06-18-2014, 16:19   #10 (permalink)
Member: 1954896
Thanks Meter: 4
i have the same problem how do you solve it? i get the baseband good but when i root the phone it get baseband unknow and i cant fix the imei
Old 06-18-2014, 16:30   #11 (permalink)
androidlabs's Avatar
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
flash rfs using odin. or try any good custom rom(zip) using custom CWM recovery you will have known baseband and imei starting from 004... then repair your imei number with any box you have for samsung which allows you to write imei number. GOOD LUCK
Babar Abbasi
Old 06-18-2014, 23:26   #12 (permalink)
AsiaGSM™'s Avatar
Member: 599306
Sonork: 100.1578386
Thanks Meter: 5,136
See info Carefully i highlight
Device Info
Model: ja3g
Phone Version:
Ril Hw Version:
Sales Code: TGY
Model ID:
Root Access: ROOTED
Time used : 1.8 s
this info show phone modam is damage and when modam damage you not able to repair IMEI and Baseband
the only way to fix IMEI is repair Modam 1st
how to repair modam:
download Modam file only that same as your phone fw and flash modam only
download full flash with pit (4 files) and flash phone
if not work means you are flashing wrong fw then you have to check phone modal on its PCB and flash correct modal fw
if not fix modam with above then your phone must be hardware
check hardware
once your Modam OK you can reapir your IMEI and Baseband
BR.
GSM BST Team
Page generated in 0.19529 seconds with 8 queries
