BST / BSTPro Dongle BestSmartTools Official Support Section |
04-11-2015, 11:31 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2151910 Status: Offline Thanks Meter: 0 | I9500 restore original imei after downgrade 5.0.1 [ANSWERED] i downgraded from 5.0.1 to 4.4.2 and the imei is null. i don't have efs backup i flashed modem and restored the original imei but CERTI: fail (not registered in network) used different CERTI and everything works just fine but not my IMEI i used bst and z3x is there any way to restore original imei and make it work? Device Info SerialNumber: 4d002013656fb015 Hardware: universal5410 Model: ja3g PDA Version: I9500XXUFNC2 Phone Version: I9500DDUHOA1 Bootloader ver: I9500XXUFNC2 Ril Hw Version: REV__ Sales Code: ILO Model ID: I9500 Get Bluetooth info failed Get WI-FI info failed Network [1]: GSM IMEI: 35763305618**** Root Access: ROOTED |
04-11-2015, 14:06 | #2 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,491 | Quote:
If you dont have original efs backup files and you already did "Wr.Default EFS" you cannot write original imei. You can try as follow way if you didnot do "Wr.Default EFS" before. 1. Flashing with 5.0.1 (I9500DDUHOA1) 2. Check imei is working or not 3. Backup SuperIMEI 4. Downgrade to 4.4.2 5. Restore original superIMEI Best Regards GsmBest Team Last edited by EmeGSM-Wei; 04-11-2015 at 14:21. | |
The Following User Says Thank You to EmeGSM-Wei For This Useful Post: |
04-11-2015, 14:10 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If you not have done all BKP of EFS, QCN, NV itc... and have write other Cert file how wat restore you original Mei?...from what?...for Write cert you have obbligatory Wiped Security/Efs so if you has used Z3X ceck good becouse you will have the EFS Bkp...with BST if not have EFS Bkp you never can restore you original Mei... But excuseme...Why you have write other Cert? for that?...sure for one razon...now if you find all Bkp and restore the original Mei...you will have the same problem....not understan why have done this procedure at this point Anyway...No Bkp No restore nothingh of original becouse wiped. BR allumts |
