BST / BSTPro Dongle BestSmartTools Official Support Section |
11-23-2016, 01:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | j500h super imei done only by bst other failed load pit from files ... Connect to device ... Device pit saved to H:\flash firmware\BST\backup\samsung\pit\SM-J500H\SM-J500H_2016-11-23_01.21.35.pit re-partition ... device pit data format not suppored Error happend while updating device Time used : 4.3 s Load PIT "C:\Users\NESSY\Desktop\J5LTE_EUR_OPEN.pit" Load PIT "C:\Users\NESSY\Desktop\J5LTE_EUR_OPEN.pit" Load PDA "H:\flash firmware\BST\Roms\Samsung\COMBINATION_OXA_FA51_J50 0FXXU1AOI2_2.bsp" ok load pit from files ... Connect to device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Time used : 0.7 s Load PIT "H:\flash firmware\BST\Roms\Samsung\COMBINATION_OXA_FA51_J50 0FXXU1AOI2_2.bsp" Exception happended : 0 [call stack] [0] : noname [1] : noname [2] : noname [3] : call noname [4] : call fea2a17768167a4a8d1cf1bf51df1e43 [5] : call 28463a14b94e55a8767621c85ae8ddbd [6] : call 73f3d99de599b63286ffb183bd2d58bf Load PDA "H:\flash firmware\BST\Roms\Samsung\COMBINATION_OXE_FA51_J50 0HXXU1AOF8.bsp" ok load pit from files ... Connect to device ... Device pit saved to H:\flash firmware\BST\backup\samsung\pit\SM-J500H\SM-J500H_2016-11-23_01.49.59.pit re-partition ... Write file aboot.mbn ... Write file boot.img ... Write file cache.img.ext4 ... Write file hyp.mbn ... Write file modem.bin ... Write file non-hlos.bin ... Write file persdata.img.ext4 ... Write file persist.img.ext4 ... Write file recovery.img ... Write file rpm.mbn ... Write file sbl1.mbn ... Write file sec.dat ... Write file system.img.ext4 ... Write file tz.mbn ... Flash completed Time used : 1 min 51 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J500H Hardware: QCOM Mode: normal Checking environment ... System Info Display ID: LMY48B System Ver: 5.1.1 REL API Level: 22 Incremental: FA51_J500HXXU1AOF8 Model: SM-J500H Brand: samsung Device: j53g Platform: msm8916 Language: en Rigion: GB Device Info SerialNumber: aaac9737 Hardware: qcom Model: j53g PDA Version: FA51_J500HXXU1AOF8 Phone Version: J500HXXU1AOF9 Bootloader ver: FA51_J500HXXU1AOF8 Ril HW ID:MP 0.400 Sales Code: Model ID: Get Bluetooth info failed Get WI-FI info failed Root Access: No root Time used : 6.1 s Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL 1 failed with MSL Bypass MSL ... This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.3 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J500H Hardware: QCOM Mode: normal Checking environment ... System Info Display ID: LMY48B System Ver: 5.1.1 REL API Level: 22 Incremental: FA51_J500HXXU1AOF8 Model: SM-J500H Brand: samsung Device: j53g Platform: msm8916 Language: en Rigion: GB Device Info SerialNumber: aaac9737 Hardware: qcom Model: j53g PDA Version: FA51_J500HXXU1AOF8 Phone Version: J500HXXU1AOF9 Bootloader ver: FA51_J500HXXU1AOF8 Ril HW ID:MP 0.400 Sales Code: Model ID: Get Bluetooth info failed Get WI-FI info failed Root Access: No root Time used : 5.3 s Bypass MSL ... This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 6.4 s Checking environment ... System Info Display ID: LMY48B System Ver: 5.1.1 REL API Level: 22 Incremental: FA51_J500HXXU1AOF8 Model: SM-J500H Brand: samsung Device: j53g Platform: msm8916 Language: en Rigion: GB Device Info SerialNumber: aaac9737 Hardware: qcom Model: j53g PDA Version: FA51_J500HXXU1AOF8 Phone Version: J500HXXU1AOF9 Bootloader ver: FA51_J500HXXU1AOF8 Ril HW ID:MP 0.400 Sales Code: Model ID: Get Bluetooth info failed Get WI-FI info failed Root Access: No root Time used : 5.5 s Bypass MSL ... This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.1 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J500H Hardware: QCOM Mode: normal Checking environment ... System Info Display ID: LMY48B System Ver: 5.1.1 REL API Level: 22 Incremental: FA51_J500HXXU1AOF8 Model: SM-J500H Brand: samsung Device: j53g Platform: msm8916 Language: en Rigion: GB Device Info SerialNumber: aaac9737 Hardware: qcom Model: j53g PDA Version: FA51_J500HXXU1AOF8 Phone Version: J500HXXU1AOF9 Bootloader ver: FA51_J500HXXU1AOF8 Ril HW ID:MP 0.400 Sales Code: Model ID: Get Bluetooth info failed Get WI-FI info failed Root Access: No root Time used : 5.8 s Bypass MSL ... done Time used : 7.2 s user canceled Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J500H Hardware: QCOM Mode: normal Checking environment ... System Info Display ID: LMY48B System Ver: 5.1.1 REL API Level: 22 Incremental: FA51_J500HXXU1AOF8 Model: SM-J500H Brand: samsung Device: j53g Platform: msm8916 Language: en Rigion: GB Device Info SerialNumber: aaac9737 Hardware: qcom Model: j53g PDA Version: FA51_J500HXXU1AOF8 Phone Version: J500HXXU1AOF9 Bootloader ver: FA51_J500HXXU1AOF8 Ril HW ID:MP 0.400 Sales Code: Model ID: Get Bluetooth info failed Get WI-FI info failed Root Access: No root Time used : 5.6 s Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Load PDA "H:\flash firmware\Samsung\Android\firmwares\MBC-J500HXWU1AOI2-20150910235849\J500HXWU1AOI2_J500HMBC1AOI2_J500HXW U1AOI1_HOME.tar.md5" ok Connect to device ... can't open device Connect to device failed, please remove the battery,manually enter download mode, then try again. Time used : 0.5 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD Connect to device ... Device pit saved to H:\flash firmware\BST\backup\samsung\pit\SM-J500H\SM-J500H_2016-11-23_02.01.41.pit Write file aboot.mbn ... Write file sbl1.mbn ... Write file rpm.mbn ... Write file tz.mbn ... Write file hyp.mbn ... Write file non-hlos.bin ... Write file sec.dat ... Write file boot.img ... Write file recovery.img ... Write file system.img.ext4 ... Write file modem.bin ... Write file cache.img.ext4 ... Write file hidden.img.ext4 ... Flash completed Time used : 4 min 22 s |
