BST / BSTPro Dongle BestSmartTools Official Support Section |
03-12-2016, 14:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | j500h super imei problem i want to write super imei for j500h i did write default efs but when i move to next step i got failed i made all preparations like drivers are good also DM+MODEM+ADB good here is LOG Code: Checking environment ... System Info Display ID: LMY48B System Ver: 5.1.1 REL API Level: 22 Incremental: J500HXXU1APB1 Model: SM-J500H Brand: samsung Device: j53g Platform: msm8916 Language: en Rigion: GB Device Info SerialNumber: 7934f0ea Hardware: qcom Model: j53g PDA Version: J500HXXU1APB1 Phone Version: J500HXXU1APA5 Bootloader ver: J500HXXU1APB1 Ril HW ID: Sales Code: MID Model ID: Get Bluetooth info failed WiFi MAC: 00:12:36:30:dc:50 WiFi interface: WiFi state: INACTIVE Root Access: No root Time used : 2.2 s Load file failed Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Connect to device ... Device Authentication ... communication failed |
03-12-2016, 16:11 | #2 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, That Means Cert Not Good !! Try Another Cert ... For Devicr Authentication Close Bat BSI Supply & Retry .. Good Luck Regards, ------------------------ GsmBest Team |
The Following User Says Thank You to ..::CHAIN::.. For This Useful Post: |
03-12-2016, 17:11 | #3 (permalink) | |
Member: 630795 Status: Offline Thanks Meter: 177 | Quote:
Code: dev[1] Manufactory: SAMSUNG Model: SM-J500H Hardware: QCOM Mode: normal Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J500H Hardware: QCOM Mode: normal Connect to device ... Device Authentication ... failed with MSL Bypass MSL ... This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. | |
03-12-2016, 21:41 | #4 (permalink) | |
03-14-2016, 08:33 | #7 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Iran-Behbahan Age: 42
Member: 1778926 Status: Offline Thanks Meter: 60 | i have same problem phone rooted and basebond ok but in final section software cannot connect to phone via uart 523k i use z3x and several box as interface but no luck please help me |
The Following User Says Thank You to 10256929 For This Useful Post: |
