BST / BSTPro Dongle BestSmartTools Official Support Section |
04-30-2016, 10:33 | #1 (permalink) | ||
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | [j7] sm-j700f xxu2apc4 2016 build frp solution {Exclusive} Till Day I Checked Many Guys Having Issue In J700F (PC4) Build FRP & Many Guys Brick Handset During Downgrade !! Anyway Let Me Explain How You Can Done Easily .... Hope You Guys Enjoy This!! 1st Download This ROM J700FXXU1AOL2/J700FODD1AOL1 GOOGLE IT * When Download Complete Open Pack Using 7zip * Now Select This img Only & Extact Quote:
* After That You Get Unforunatly Error So Simply Wipe Data & Cache Using Recovery. * Now Connect Handset To Wifi & Open Sidesync * Choose Internet Browser & Type This --- alnajat.co/setting.apk * Then Go To Bookmark - History - Download History -- & Install Apk. * Then Open Apk & Click About & Enable Devloper - OEM * Finally Reset Your Phone !! FRP GONE * If Developer Not Enable Then Follow Full Guide Of Sidesync Quote:
Regards, __________ GsmBest Team | ||
The Following 23 Users Say Thank You to ..::CHAIN::.. For This Useful Post: |
05-01-2016, 20:57 | #6 (permalink) |
No Life Poster Join Date: Jun 2007 Location: E G Y P T Age: 37
Member: 527884 Status: Offline Sonork: 100.1583794 Thanks Meter: 850 | To Be More Easy Just Open Firmware Using 7Zip And Delete the Files Just Let Boot.img Recovery.img System.img After Delete Files Flash Phone By Any Box Because Odin Will Not Flash The Files After ou Edit It Regards |
05-02-2016, 16:21 | #10 (permalink) | |
Crazy Poster Join Date: Jun 2013 Location: Ranchi Age: 32
Member: 1962881 Status: Offline Sonork: 100.1656866 Thanks Meter: 18 | Not Working..... Quote:
This method not working today i'm checking 10 times....but not solved..every times after reset...set reboot and goes on FRP.....also flash .Bsp file by Bst...not working Till day... | |
05-03-2016, 08:07 | #11 (permalink) | ||
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Quote:
Hello, Check Complete Thread 1st Its Only For PC4 Build & After Flash You Need To Done With Sidesync !! Quote:
The Following 2 Users Say Thank You to ..::CHAIN::.. For This Useful Post: |
05-07-2016, 01:18 | #13 (permalink) |
Major Poster Join Date: Jan 2010 Location: india Age: 49
Member: 1206892 Status: Offline Thanks Meter: 12 | successful details for j700f/ds frp on xxu2apc4. easiest way i found after spending 5hours.. 1. install http://downloadcenter.samsung.com/co...c_4.3.0.92.exe 2.power on the device ,install all needed drivers, open sidesync on your system and connect the device 3. in bottom of your device it prompts browser option, use internet browser, and in above search , search for alnajat.co/setting.apk [thanks for http://forum.****************** for giving me the way to find my own easy way] 4. in bottom Click on Bookmarks -> History -> Download history 5. install settings.apk 6. go to lock screen and security - other settings and disable all device administrators you find there. 7.i cleared all apps caches and data in app manager {i am not sure of this, but you try it wen it not worked, coz i had only one set in my hand} 8. go to about phone and activate debug and activate oem unlocking {i could not activate debug for first time i tried from 1 to 7 for 4times then i succeeded to activate debug}{in mean time i played with standard mode and easy mode for same 4times} 9. after activating oem unlocking just go to back up and reset in device and wipe all data and enjoy...... this was my successful story. and i have given all by step by step.. dont comment wrongly for your mistakes. just give thanks coz it works 1000% |
The Following 5 Users Say Thank You to karanth For This Useful Post: |
05-07-2016, 08:55 | #14 (permalink) | |
Member: 1962881 Status: Offline Sonork: 100.1656866 Thanks Meter: 18 | Yeah,,100% worked..with any build...:D :D Quote:
Br,Hassan Khan | |
The Following 2 Users Say Thank You to khanwasim1991 For This Useful Post: |
05-08-2016, 08:29 | #15 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1961084 Status: Offline Sonork: 1068210408 Thanks Meter: 2 | Thank you Mr. CHAIN Finally. I succeeded to remove google account of sm-j700f (4 pieces) |
The Following 2 Users Say Thank You to nezarwin For This Useful Post: |
