BST / BSTPro Dongle BestSmartTools Official Support Section |
05-15-2016, 20:22 | #16 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
The Following 2 Users Say Thank You to allumts For This Useful Post: |
05-18-2016, 10:48 | #17 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Hello This Trick also Work In J700FXXU2APD8 But No Need To downgrade and flash any file just follow Sidesynce Method ::bR-Rehan:: |
The Following 2 Users Say Thank You to rehansk8879 For This Useful Post: |
05-21-2016, 20:18 | #18 (permalink) |
Major Poster Join Date: Jan 2010 Location: india Age: 49
Member: 1206892 Status: Offline Thanks Meter: 12 | sorry to have this type of blames. i have already mentioned and thanked for information which i got from and also mentioned the source.. and also i have included my own methods and experience. i am here to just learn and i thought it would be easy who are having prob in new updates. again i am sorry if i have hurted any one in forum. |
The Following User Says Thank You to karanth For This Useful Post: |
05-21-2016, 21:49 | #19 (permalink) | |
No there nothing of you but all procedure from 1 step to latest is Full copied. In other forum i not believe will be happy that you coming here to share, and where share, in one Tool/Dongle section, it's very bud action, if want help for TRUE other users Share in GENERAL SECTION, where there are many users cannot purchase any Box/dongle. It's my point of wiew and not think i'm wrong. | |
The Following User Says Thank You to allumts For This Useful Post: |
05-24-2016, 23:38 | #20 (permalink) |
Freak Poster Join Date: Sep 2013 Location: in your Heart
Member: 2025719 Status: Offline Thanks Meter: 50 | thanks to rootjunky for frp reset and its works 100%%% NoW thanks to Bst Tool For Note 5 N920C frp ereased successfully |
The Following User Says Thank You to Muazzam786 For This Useful Post: |
06-07-2016, 07:25 | #22 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Quote:
Mean When Install Done Click Direct OPEN After Click You Will See Setting MENU Then Click About --> Tap on BUILD 7 Times --> Devloper Menu --> Enable OEM UNLOCK --> Enale USB DEBUGG ... Then Finally Factory Reset .. Regards, __________ GsmBest Team | |
06-11-2016, 12:43 | #23 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Thank you Mr. CHAIN . Finaly Tested 2 pcs j700F new sec ....work 100% |
The Following User Says Thank You to kushol For This Useful Post: |
07-16-2016, 01:01 | #25 (permalink) |
Major Poster Join Date: Aug 2009
Member: 1091149 Status: Offline Thanks Meter: 2 | Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Device Info (MTP) Model: CONINFO IMEI: PDA Version: Phone Version: CSC : CSC Version: Time used : 1 min 0 s Device Info (MTP) Model: IMEI: PDA Version: Phone Version: CSC : CSC Version: Time used : 1 min 10 s Reboot device to DOWNLOAD mode ... Wait device ready ... Unlocking device ... can't get response from device Connect to device failed, please remove the battery,manually enter download mode, then try again. plz helm me sir give me good sol.... thanq |
07-18-2016, 11:49 | #27 (permalink) |
No Life Poster Join Date: Dec 2000 Location: las palmas ,spain
Member: 2800 Status: Offline Thanks Meter: 47 | This solution not working for J700h 6.0.1,is there any firmware for this model where i can extract boot,img without getting error while flashing? |
08-03-2016, 14:11 | #29 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @mundatelecom, You have Last BUILD FW installed and i not belive that BST can work in Reset MSL for Unlock/Write Cert/Superimei with this last BUILD of FW.... Other Box like Octopus, Z3X itc....can do it w/o root |
