BST / BSTPro Dongle BestSmartTools Official Support Section |
12-12-2015, 15:03 | #1 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Syria-Turkey
Member: 2292083 Status: Offline Thanks Meter: 130 | J700H Super Imei Problem dev[1] Manufactory: SAMSUNG Model: SM-J700H Hardware: SAMSUNGEXYNOS7580 Mode: normal ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Cables: MicroUART Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Prepare environment ... Time used : 0.3 s Backup EFS ... D:\BST\backup\samsung\efs\SM-J700H\EFS_samsung_SM-J700H__2015-12-12_03.00.55.efs ok Wiping EFS ... ok Connect to device ... Device Authentication ... 1 failed with MSL |
12-12-2015, 15:21 | #2 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, Try This * Write Default Efs * Write Super IMEI * Write Efs Back (If Needed) Regards, ___________ GsmBest Team |
The Following User Says Thank You to ..::CHAIN::.. For This Useful Post: |
12-12-2015, 15:54 | #3 (permalink) |
Member: 2292083 Status: Offline Thanks Meter: 130 | Same Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J700H Hardware: SAMSUNGEXYNOS7580 Mode: normal Reboot device to DOWNLOAD mode ... Wait device ready ... Connect to device ... Repair EFS ... Flash completed Time used : 2.8 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J700H Hardware: SAMSUNGEXYNOS7580 Mode: normal Connect to device ... Device Authentication ... 1 failed with MSL |
The Following User Says Thank You to khalidhoms For This Useful Post: |
04-10-2016, 18:18 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | WARNING. Most of android 6.0.1 phones after touch knox(if knox = 1), will have big problem with unlock or repair. Be carefull with root method. DONT TRY ROOT which can trigger knox to 1, because original MSL bypass method unlock will not work, even you cant unlock phone with original MSL.!!!!! If solution will ready - we will put public. |
The Following User Says Thank You to oktay50000 For This Useful Post: |
