BST / BSTPro Dongle BestSmartTools Official Support Section |
12-26-2017, 16:33 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | mi 2016090 mi account need help > Backup phone original QCN before Repair IMEI or Erase IMEI/NVM. 1. Power on the phone and enable "USB Debugging" option. 2. Connect phone to pc via USB cables. 3. Dial(*#*#717717#*#*), Enable Qualcomm Diag port. 4. Press "Scan" button to confirm phone connected. 5. Press "EraseIMEI" (or Press "EraseNVM") 6. Repair IMEI 7. Repair Network [Screen Lock] 1. Enter fastboot mode (install drivers if needed) 2. Press "OneKey Recovery" 3. Waiting phone enter recovery mode 4. Press "Scan" and then press "Reset Screenlock" Tips: If you device Bootloader locked, have to unlock bootloader lock before Remove screenlock. [Account Lock] 1. Enter Fastboot or EDL mode (install drivers if needed) 2. Press "Scan" and then press "Reset Account Lock" Tips: 1).If phone locked still or Wifi not working, please do WIPE or flash firmware to fix problem. 2).If phone auto relock after online, please use "Patch Account Lock Relock" or "Disable Account Lock Relock" to fix problem [Factory Reset] 1. Enter Fastboot or EDL mode (install drivers if needed) 2. Press "Scan" and then press "Factory Reset" Perform device factory reset ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Scanning devices ... 1 found dev[1] ae6f9bea Mode: fastboot Hardware: ***** Manufactory: UNKNOWN MID: Detect 1 USB devices not install driver Perform device factory reset ... Boot to EDL mode ... done Wait device ready ... timeout Removing Account Lock ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Perform device factory reset ... Boot to EDL mode ... done Wait device ready ... timeout ---------------------------------------------------- We strongly recommend backup userdata before unlock Google Account Lock Some device can't boot to system after unlock Google Account Lock , execute Factory Reset or enter Recovery Mode,Wipe userdata could fix this. ---------------------------------------------------- Removing Account Lock ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! This operation need boot to normal mode Reboot device to NORMAL mode ... Wait device ready ... Stopping current operation ... Read Userdata Partition ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Exception happended : operation stopped by user Start unlock ... Scan device first Removing Account Lock ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Perform device factory reset ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Perform device factory reset ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Perform device factory reset ... Boot to EDL mode ... Failed, Enable ADB or fastboot try again! Scanning devices ... 1 found dev[1] ae6f9bea Mode: fastboot Hardware: ***** Manufactory: UNKNOWN MID: Detect 1 USB devices not install driver Perform device factory reset ... Boot to EDL mode ... done Wait device ready ... timeout Log saved to: C:\Users\abuthahir\Documents\Log 2017-12-26 20.59.40.txt how to remove mi account ? i am new user in bst |
12-27-2017, 17:46 | #2 (permalink) | |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | Quote:
Then Reset Mi Account | |
