BST / BSTPro Dongle BestSmartTools Official Support Section |
04-24-2015, 13:00 | #2 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, Try Always Send Full Logs/Screenshot For Faster Help. Regards, __________ GsmBest Team |
The Following User Says Thank You to ..::CHAIN::.. For This Useful Post: |
04-25-2015, 00:30 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: in the cellphone
Member: 352414 Status: Offline Thanks Meter: 41 | Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Device Info (UART) Model: SM-N910A SW Version: N910AUCU1COC4 Customer Code: ATT Unique Number: CR20025B9D8B0C1 Flash Memory: - Chipset : true Time used : 1.6 s Manufactory: SAMSUNG Model: SM-N910A Hardware: QCOM Mode: normal Checking environment ... System Info Display ID: LRX22C System Ver: 5.0.1 REL API Level: 21 Incremental: N910AUCU1COC4 Model: SAMSUNG-SM-N910A Brand: samsung Device: trlteatt Platform: apq8084 Language: en Rigion: US Device Info SerialNumber: 25b9d8b0 Hardware: qcom Model: trlteatt PDA Version: N910AUCU1COC4 Phone Version: N910AUCU1COC4 Bootloader ver: N910AUCU1COC4 Ril Hw Version: Sales Code: ATT Model ID: Get Bluetooth info failed WiFi MAC: c0:bd:d1:74:f4:cc WiFi interface: WiFi state: SCANNING Root Access: No root Time used : 3.4 s Last edited by uburo22; 04-25-2015 at 00:37. |
The Following User Says Thank You to uburo22 For This Useful Post: |
04-25-2015, 02:01 | #4 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Online Thanks Meter: 6,491 | Quote:
We dont known whats problem facing!!! tell us problem in more details please. SM-N910A repair imei as follow way: 1. Wipe EFS 2. Write SuperIMEI ( or write cert) 3. Repair Network ( or write qcn) You can wipe efs with command directly: ---------------------------------------------------------------------------------------------------- 1. Type *#9090# 2. MENU + choice Back (right coner) 3. MENU + input Q (right coner) 4. MENU + input 0000 (right coner) 5. wait about 10 second display 'MAIN MENU' 6. UE SETTING & INFO > SETTING > SYSTEM > NV BACKUP TEST > ERASE ALL EFS1/2/3 > YES ---------------------------------------------------------------------------------------------------- Best Regards GsmBest Team Last edited by EmeGSM-Wei; 04-25-2015 at 02:06. | |
04-25-2015, 23:55 | #5 (permalink) |
Member: 352414 Status: Offline Thanks Meter: 41 | 1. Wipe EFS 2. Write SuperIMEI ( or write cert) 3. Repair Network ( or write qcn) You can wipe efs with command directly: ---------------------------------------------------------------------------------------------------- 1. Type *#9090# 2. MENU + choice Back (right coner) 3. MENU + input Q (right coner) 4. MENU + input 0000 (right coner) 5. wait about 10 second display 'MAIN MENU' 6. UE SETTING & INFO > SETTING > SYSTEM > NV BACKUP TEST > ERASE ALL EFS1/2/3 > YES i did all what i need to do is change imei that is all one more thing n910a 4.4.4 is working but 5.0.1 is not working |
04-26-2015, 01:23 | #6 (permalink) | |
Show me the problme in more details please, now i dont known any problem you facing. NOTE4 UART COMMUNICATION: BST-Samsung Note4 N910x_G901x_G850x_G800x UART communication enable! - Support - GsmBest Team Tips: Contact me with my skype ([email protected]) if not working still Best Regards GsmBest Team | |
08-02-2015, 22:56 | #11 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2438527 Status: Offline Thanks Meter: 0 | anning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Device Info (UART) Model: SAMSUNG-SM-N910A IMEI: PDA Version: N910AUCU1ANIE Phone Version: CSC : N910AATT1ANIE CSC Version: N910AUCU1ANIE Time used : 13.0 s Connect to device ... Device Authentication ... 1 failed with MSL help please |
08-03-2015, 14:58 | #12 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 527921 Status: Offline Thanks Meter: 23 | Downgrade You need to downgrade the firmware to see what GSM WEI is suggesting. It will not show up in lollipop. Marvel12 you need to start all the steps from beginning and your issues will be resolved. Key is to wipe EFS |
08-03-2015, 17:49 | #13 (permalink) | |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote:
Key is to wipe EFS, you will need ROOT for this if you're going to do it via adb, or you can always do it in download mode Last edited by F_X; 08-03-2015 at 17:56. | |
