BST / BSTPro Dongle BestSmartTools Official Support Section |
04-07-2015, 11:40 | #1 (permalink) |
Insane Poster Join Date: Feb 2014
Member: 2128896 Status: Offline Thanks Meter: 8 | n910h emergency call [ANSWERED] i have samsung sm-n910h null/null i write super imei but no network only emergency call what shall i do please help me i need efs file for n910h badly thanks |
04-08-2015, 12:48 | #2 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,491 | Quote:
Check phone baseband working or not 1st, read info and then post logs, *#0011# take a photo. Best Regards GsmBest Team | |
The Following User Says Thank You to EmeGSM-Wei For This Useful Post: |
02-02-2017, 08:54 | #7 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | i did the same finally done while othes fails GOOD WORK BST Fw.Ver : BstKey V3.34 Serial : 3C9C-9E74-5E39-7015 Active User: Nessyb PL2303 : 3.8.3.0 2016-10-06 Best Smart Tools, Load OK. Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-N910H Hardware: UNIVERSAL5433 Mode: normal ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Cables: MicroUART Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Checking environment ... System Info Display ID: LMY47X System Ver: 5.1.1 REL API Level: 22 Incremental: N910HXXU2COJ4 Model: SM-N910H Brand: samsung Device: tre3g Platform: exynos5 Language: en Rigion: GB Device Info SerialNumber: 41003b06e41ba18b Hardware: universal5433 Model: tre3g PDA Version: N910HXXU2COJ4 Phone Version: N910HXXU1COJ2 Bootloader ver: N910HXXU2COJ4 Ril HW ID: Sales Code: XFA Model ID: Get Bluetooth info failed WiFi MAC: c0:bd:d1:0e:8f:93 WiFi interface: WiFi state: INACTIVE Root Access: No root Time used : 6.1 s Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Device Info (UART) Model: SM-N910H SW Version: N910HXXU2COJ4 Customer Code: XFA Unique Number: CR2003B06E41BA1 Flash Memory: - Chipset : true Key ID : 0065 Time used : 11.2 s Verify Phone Cert ... Failed Read device info ... done Time used : 1.2 s Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Prepare environment ... Device do not have ADB interface, turn on device USB DEBUG and connect with usb cable,then re-scan device Need reboot device to normal Time used : 0.0 s Connect to device ... Device Authentication ... 1 failed with MSL Connect to device ... Device Authentication ... 1 failed with MSL Reboot device to DOWNLOAD mode ... communication failed Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-N910H Hardware: UNIVERSAL5433 Mode: normal Reboot device to DOWNLOAD mode ... Re-scan device before any operation please Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD Connect to device ... Repair EFS ... Flash completed Time used : 1.9 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-N910H Hardware: UNIVERSAL5433 Mode: normal Checking environment ... System Info Display ID: LMY47X System Ver: 5.1.1 REL API Level: 22 Incremental: N910HXXU2COJ4 Model: SM-N910H Brand: samsung Device: tre3g Platform: exynos5 Language: en Rigion: GB Device Info SerialNumber: 41003b06e41ba18b Hardware: universal5433 Model: tre3g PDA Version: N910HXXU2COJ4 Phone Version: N910HXXU1COJ2 Bootloader ver: N910HXXU2COJ4 Ril HW ID: Sales Code: XFA Model ID: Get Bluetooth info failed WiFi MAC: c0:bd:d1:0e:8f:93 WiFi interface: WiFi state: INACTIVE Root Access: No root Time used : 5.5 s Prepare environment ... need root access Time used : 4.5 s Checking environment ... System Info Display ID: LMY47X System Ver: 5.1.1 REL API Level: 22 Incremental: N910HXXU2COJ4 Model: SM-N910H Brand: samsung Device: tre3g Platform: exynos5 Language: en Rigion: GB Device Info SerialNumber: 41003b06e41ba18b Hardware: universal5433 Model: tre3g PDA Version: N910HXXU2COJ4 Phone Version: N910HXXU1COJ2 Bootloader ver: N910HXXU2COJ4 Ril HW ID: Sales Code: XFA Model ID: Get Bluetooth info failed WiFi MAC: c0:bd:d1:0e:8f:93 WiFi interface: WiFi state: INACTIVE Root Access: No root Time used : 5.8 s Prepare environment ... need root access Time used : 4.5 s Load Phone "C:\Users\NESSY\Desktop\CF-Auto-Root-tre3g-tre3gxx-smn910h.tar.md5" It seems this is not a phone rom,Continue flash may bricking your device or unknown baseband!ok Reboot device to DOWNLOAD mode ... Re-scan device before any operation please Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD It seems this is not a phone rom,Continue flash may bricking your device or unknown baseband!Connect to device ... Device pit saved to H:\flash firmware\BST\backup\samsung\pit\SM-N910H\SM-N910H_2017-02-02_09.45.09.pit Write file recovery.img ... Write file cache.img ... Flash completed Time used : 6.7 s Prepare environment ... Device do not have ADB interface, turn on device USB DEBUG and connect with usb cable,then re-scan device Need reboot device to normal Time used : 0.0 s Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Device Info (MTP) Model: SM-N910H IMEI: 350050500009692 PDA Version: N910HXXU2COJ4 Phone Version: N910HXXU1COJ2 CSC : N910HOJV2COJ1 CSC Version: N910HXXU2COJ4 Time used : 22.8 s Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-N910H Hardware: UNIVERSAL5433 Mode: normal Checking environment ... System Info Display ID: LMY47X System Ver: 5.1.1 REL API Level: 22 Incremental: N910HXXU2COJ4 Model: SM-N910H Brand: samsung Device: tre3g Platform: exynos5 Language: en Rigion: GB Device Info SerialNumber: 41003b06e41ba18b Hardware: universal5433 Model: tre3g PDA Version: N910HXXU2COJ4 Phone Version: N910HXXU1COJ2 Bootloader ver: N910HXXU2COJ4 Ril HW ID: Sales Code: XFA Model ID: Get Bluetooth info failed WiFi MAC: c0:bd:d1:0e:8f:93 WiFi interface: WiFi state: INACTIVE Root Access: ROOTED Time used : 11.2 s Prepare environment ... Backup EFS ... H:\flash firmware\BST\backup\samsung\efs\SM-N910H\EFS_samsung_SM-N910H__2017-02-02_09.49.02.efs ok Wiping EFS ... ok Time used : 23.7 s Reboot device to NORMAL mode ... Re-scan device before any operation please Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-N910H Hardware: UNIVERSAL5433 Mode: normal Checking environment ... System Info Display ID: LMY47X System Ver: 5.1.1 REL API Level: 22 Incremental: N910HXXU2COJ4 Model: SM-N910H Brand: samsung Device: tre3g Platform: exynos5 Language: en Rigion: GB Device Info SerialNumber: 41003b06e41ba18b Hardware: universal5433 Model: tre3g PDA Version: N910HXXU2COJ4 Phone Version: N910HXXU1COJ2 Bootloader ver: N910HXXU2COJ4 Ril HW ID: Sales Code: XFA Model ID: Get Bluetooth info failed WiFi MAC: c0:bd:d1:0e:8f:93 WiFi interface: WiFi state: INACTIVE Root Access: ROOTED Time used : 5.7 s Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device |
