BST / BSTPro Dongle BestSmartTools Official Support Section |
08-01-2014, 05:39 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 47
Member: 53422 Status: Offline Thanks Meter: 20 | New Dongle - pl2303 uart connection failed Can anyone help? Fw.Ver : BstKey V3.14 Serial : 20E5-XXXXXXXXXX Active User: betxxx PL2303 : 3.4.48.272 2013-02-05 (OK) Best Smart Tools, Load OK. Restarting ADB service ... ok Scanning devices ... 0 found Device Info (UART) ... failed Time used : 9.2 s Driver installed ok. Won't connect at all in uart with 523k cable (usb and rj45 in) Any ideas? |
08-01-2014, 21:08 | #2 (permalink) | |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | Quote:
scan button for USB only | |
The Following User Says Thank You to AsiaGSM™ For This Useful Post: |
08-04-2014, 01:07 | #3 (permalink) |
Member: 53422 Status: Offline Thanks Meter: 20 | Thank you unlock King but still have issues. Unless I press scan, the info button remains greyed out. I can't select the interface without pressing scan? Is there a manual for this soft at all? I must be getting old. Thank you again. |
08-04-2014, 01:25 | #4 (permalink) |
Member: 53422 Status: Offline Thanks Meter: 20 | Also when I try to make uart connection for imei restore it can't find device. Tried uart modem and also pds same result. developer options on. usb de bug one. Should phone it be in normal mode? or boot? If I start in normal mode connected to usb then do a swap I get connection failed at uart part where I select serial uart |
08-06-2014, 03:52 | #5 (permalink) | |
