BST / BSTPro Dongle BestSmartTools Official Support Section |
02-03-2015, 18:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Pescara, Italy
Member: 2141071 Status: Offline Sonork: 100.1653717 Thanks Meter: 15 | No imei repair gt-i8190 [ANSWERED] Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I8190 Hardware: SAMSUNGGOLDEN Mode: normal Prepare environment ... verify data failed,please check write the correct file or cable connection Prepare environment ... verify data failed,please check write the correct file or cable connection Time used : 2.8 s I've tried to downgrade...root is ok...cable is ok it's all ok but always get this problem i've tried with two different phone gt-i8190 but always same problem. |
02-06-2015, 06:38 | #4 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,491 | Quote:
GT-I8190 IMEI Repair as follow way: 1. Power on the phone, connect phone to pc via usb cables (install drivers) 2. Go "Service > Repair" tabs, fill your imei 3. Press "Write" button 4. Change R523K Uart cables when software requesting UART cables. 5. Select UART cables com port and then press "OK" 6. IMEI Repair Done Best Regards GsmBest Team | |
