BST / BSTPro Dongle BestSmartTools Official Support Section |
12-21-2015, 08:44 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | please help BST guys, S3 Error cant connect by UART connection failed :-( [ANSWERED] i AM TRYING TO REPAIR imei, BUT i AM GETTING THIS ERROr I GET THIS ERROR "" CANT CONNECT TO DEVICE PLEASE CHECK THE CABLE CONNECTION, COMMUNICATION FAILED "" logs """ Checking environment ... System Info Display ID: JSS15J System Ver: 4.3 REL API Level: 18 Incremental: I747MVLUEND2 Model: SGH-I747M Brand: samsung Device: d2can Platform: msm8960 Language: en Rigion: GB Device Info SerialNumber: 1b7063c8 Hardware: qcom Model: d2can PDA Version: I747MVLUEND2 Phone Version: I747MVLUEND2 Bootloader ver: I747MVLUEND2 Ril HW ID: Sales Code: TLS Model ID: Get Bluetooth info failed Get WI-FI info failed Root Access: ROOTED Android - 4.3 Time used : 2.1 s user canceled Time used : 2 min 5 s user canceled Time used : 33.7 s """" ## - when bst ask, i ENTER THE *#0*# ON PHONE AND THEN AFTER i CONNECT UART CABLE TO PHONE ## - I have already COVERED BATTERY POINT ##i HAVE *#0808*# dm+MODEM+ADB MODE ENABLED STILL I GET THIS ERROR "" CANT CONNECT TO DEVICE PLEASE CHECK THE CABLE CONNECTION, COMMUNICATION FAILED "" pLEASE HELPPPPPPPPPPPPPPPP |
12-21-2015, 21:55 | #4 (permalink) |
Major Poster Join Date: Jan 2011
Member: 1489224 Status: Offline Thanks Meter: 7 | type *#0808# and choose DM+MODEM+ADB rescan....this put phone in QCDI mode... http://forum.gsmhosting.com/vbb/f891...wered-1792455/ |
12-22-2015, 23:34 | #7 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, You Need Put You Phone In QCDI Mode Just Dail *#1234# & check modem = ¿ ? If unknown Just Flash Another Modem Then Try Code.Will Work After That.... Good Luck Regards, ---------- GsmBest Team |
12-23-2015, 12:50 | #12 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | And NEVER Cover Battery in these old model, this Tip was only for NEW Samsung like Note4, (N910), S5, (G900) for sure just solved from many time. Covering Battery isn't GOOD things, was used only in Emergency case, this can Short you phone becouse is Bad alimentaded, anyway NOT use more, no must need, (in particular for these Old model). BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
12-28-2015, 02:32 | #14 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | try another flash repeat the process please admin closed this post Christina already repair thank you Last edited by ghacks; 12-28-2015 at 02:38. |
12-28-2015, 17:42 | #15 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
What need of answer to you now?, repair with you other Box? Anyway, read and apply same above procedure done with Success from BST BR allumts | |
